Scan To email (gmail) Konica Minolta Bizhub E Series
  • wseyller
    • Sep 2012
    • 1129
    Today I had two of these. Two different customers. Has been working but just recently stopped working.
    I created both gmail accounts for the customer in the past and I know the password. I have turned on access for less secure apps.
    Both have stopped working.
    One of them shows a "Forward TX error", the other I'm not sure what error it shows.
    I have checked all the email tx settings. Re-entered the password. Logged into the account at gmail.com.
    the gmail account is entered into all fields such as authentication, administrator email address & device email address.
    Have tried SSL 465 and StartTLS 587
    Verified gateway & dns settings. Also have additional dns such as google's dns.
    Can ping smtp.gmail.com from the copiers.
    Other than that only thing I can think of I have tried is to factory reset the copier and set it back up. I have had to do that on an E series before to get it to scan to email on any server. But wanted to see if I'm missing something. I have set up 100s of these and have done many with gmail with little issue.
    All other setting in email tx look standard default besides what I list above.
    I even tried another account that I know 100% works.
    • 37532
    Re: Scan To email (gmail) Konica Minolta Bizhub E Series
    Have they changed their internet provider? Some ISP, AT&T Uverse for one, block all SMTP from a MFP to any server except their own. Also, if they have changed their router to one with an active firewall, it might need to be configures to allow the MFP to send.
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      Even if they haven't changed ISPs, that doesn't mean their current ISP hasn't changed the rules without announcing the move.
      And yes, as you stated, it is quite possible (if not easy) to determine that the SMTP traffic is being generated from a device, and not a workstation or mobile unit. I understand this is done to help cut down on the proliferation of spam.
      • wseyller
        • Sep 2012
        • 1129
        I will check to see if I can telnet to gmail server on ports 465 and 587. The provider are local companies which I have experience with and have never blocked access to gmail from bizhubs that I have ever seen.
        Sent from my XT1254 using Tapatalk
        • speedtek
          • Apr 2013
          • 46
          We had around 25 service calls come in yesterday for scan to e-mail problems. I am on the phone with one of the customers right now and he is having the exact same problem as you. This may be widespread. If I find anything out I will report back.
          • CompyTech
            Super Tech
            • Feb 2011
            • 706
            Could be a security setting within gmail settings itself.. I once got the forward TX error because gmail was blocking a suspicious login(the copier trying to authenticate).
            • KingofMorton
              • Apr 2015
              • 23
              Google changed their TSL from x.0 to x.2 Wednesday night and it has been reeking havoc on the 4 and 4e machines. My company is on this with KMBS about a fix.
              • wseyller
                • Sep 2012
                • 1129
                I have noticed other techs in my company getting scan to email calls using gmail. Would the tls change affect ssl because it didn't work either.
                • habik
                  • 2013
                  Try setting up a temporary new gmail. I had C220 with customer using gmail happily then oine day, not a chance. Have made new gmail account and it worked. I think it might be new terms and conditions.
                  Firmwares HERE
                  • wseyller
                    • Sep 2012
                    • 1129
                    I got more calls now as well. Not sure if those are gmail relate yet. I have another tech call me earlier today for a call he has. He can ping gmail server but wont work.
                    • speedtek
                      • Apr 2013
                      • 46
                      I've got about 50 open calls all with this problem. I am just going down the list informing the customer that it's a known issue and that we are working on it, and setting up SMB scanning for the ones that absolutely have to have some sort of scanning right now. I also opened a ticket with KM so that they can update me if something turns up.
                      • wseyller
                        • Sep 2012
                        • 1129
                        I just got an email from our office to give instructions to scan with USB stick while issues with gmail are sorted out.
                        • hand1487
                          Been dealing with this issue as well.
                          There is a special firmware on Konica for the fix. J6 I believe, hope this helps.
                          • wseyller
                            • Sep 2012
                            • 1129
                            KM just released a tech bulletin on the issue. #9876
                            • 1twig
                              • Apr 2013
                              • 12
                              I just started having the same problem worked fine for year and a half and now g mail quit working. What I did is I had my customer create a outlook account and
                              here are the settings i used that worked.
                              SMTP Server : smtp.live.com Host name checked box
                              SMTP Port : Change port 25 to 587
                              Start TLS : will allow to change port from 25 to 587
                              User name and password
                              Domain : smtp.live.com
                              I did this on a C364 and a C284e no problems with it.
                              I also talked to konica Minolta DSC tech support they said that they some problems and requested a firmware update.
                              to fix this bug from Japan
                              1twig
