Kyocera CS-3500ci Send Incoming fax to a folder?
  • BabblingXombie
    • Jun 2015
    • 32
    Kyocera CS-3500ci fax forward to a folder?
    Hi all. I have a issue with a kyocera cs-3500ci setting up incoming faxes to bypass the paper and just send it to a folder. Any help would be greatly appreciated.
    Thank You
  • XaR0uLiS
    • Jul 2014
    • 23
    Re: Kyocera CS-3500ci Send Incoming fax to a folder?
    What is exactly the problem? Could you describe it?
    • Brianneoe
      • May 2015
      • 318
      Working on Kyocera's for 10 years, never seen it on a one of their units. Ricoh yes and I guess other manufacturers also...
      • Luther
        • May 2006
        • 682
        It's called fax forwarding...try this link https://www.kyoceradocumentsolutions...o__videos.html
