GMX Alternative
  • CanonSco
    Man About Town
    • Jul 2010
    • 368
    GMX Alternative
    Seems GMX email have a freeze on new accounts.
    What other port 25 smtp services are people using?
    Cheers,
    Yes, I am a nerd.
    Gaming PC - check. Raspberry Pi - Check. Custom ROM on phone - check. Thick glasses - check.
    • 37572
    Re: GMX Alternative
    You can try gmail or check to see if the customer uses Google Apps.
    Set up a device or app to send email through Google Workspace Who this article is for This article is for Google Workspace administrators who want to send email from devices or apps in their
    • wseyller
      • Sep 2012
      • 1129
      Re: GMX Alternative
      There is inbox.com but some limitations on free accounts.
      Sent from my XT1254 using Tapatalk
      • CanonSco
        Man About Town
        • Jul 2010
        • 368
        Re: GMX Alternative
        Originally posted by terramobil
        The SMTP Ports 465 and 587 should work.
        As the original post, I am looking for smtp services that use port 25 specifically.
        GMX has been working pretty well for small businesses , but have a freeze on new accounts atm.
        Yes, I am a nerd.
        • knobby
          • Oct 2008
          • 75
          Re: GMX Alternative
          And inbox.com is down !
          Sent from my HTC One_M8 using Tapatalk
          • rthonpm
            • Aug 2007
            • 2859
            Re: GMX Alternative
            You can always set up Stunnel on a workstation that won't go to sleep, or on a customer's server that can relay the scan job over port 25 to their actual mail server.
            • sandmanmac
              • 3985
              Re: GMX Alternative
              I don't know about over in Scotland, but over here, there are several ISP's that block all connections on port 25.
              I am, however, curious why you're only interested in port 25 solutions?
              Side note:
              GMX? I don't know about now, but I broke all ties with that service several years ago, when I was using it as a workaround for some of my clients, and their server went down for at least 6 months straight!! What a nightmare that created!
                • 37572
                Re: GMX Alternative
                Might be using an older MFP that does not support SMTP over SSL. It would have been nice if he had identified what MFP was being used.
                I do not know about current but a coupe of years our web services were hosted by GoDaddy. Their email server also supported SMTP on port 80.
                • sandmanmac
                  • 3985
                  Re: GMX Alternative
                  That's sort of what I was getting at. If it doesn't support SSL, there's a bunch of other options on other ports.
                  The Smtp2go service runs on ports 587, 2525 or 8025, and I've never had a problem with it.
                  Most Web hosting services that I've come across also offer an non-SSL solution over a number of ports other than 25. I set one up just recently on GO Daddy using port 80 (as you said), and Host Papa's another one that comes to mind using port 587.
                    • 37572
                    Re: GMX Alternative
                    The nice thing about port 80 is that it cannot be blocked without blocking browser access to the internet.
                    • Mr Spock
                      Vulcan Inventor of Death
                      • Aug 2006
                      • 2064
                      Re: GMX Alternative
                      I have an enterprise account that blocks port 80. They have all browsers set for 8080 to get through the internet appliance. End user login to the domain with single signon and that enables them to get through the appliance while all other attempts are blocked. So it can be done just not financially reasonable for any small companies.
                      • Tech Helpdesk
                        • Jul 2015
                        • 112
                        Re: GMX Alternative
                        Try Mail.com
                        • CanonSco
                          Man About Town
                          • Jul 2010
                          • 368
                          Re: GMX Alternative
                          Thanks. Maybe I should have qualified it a little
                          I was looking for some reliable, free non SSL /TLS providers. I am aware of and have used all of the above at some point.
                          GoDaddy / SMTP2Go / HostPapa et al all have costs associated.
                          It was not for a specific machine per say , more a general question to put some feelers out. Shame GMX is up and down like a proverbial Yo-Yo.
                          Thanks again.
                          Yes, I am a nerd.
                            • 37572
                            Re: GMX Alternative
                            Thanks again.
                            Then use gmail's port 25 smtp service. You will be limited sending only to other gmail and Google Docs accounts.
                            • CanonSco
                              Man About Town
                              • Jul 2010
                              • 368
                              Re: GMX Alternative
                              https://support.google.com/a/answer/176600?hl=en
                              Yes, that coupled with forwarding on Gmail can work to a single address quite well.
                              Yes, I am a nerd.
