Hi
Does any one know which is the best solution required to connect a konicaminolta copier for for high volume printing in an IBM environment deatils of the server and OS given below.
--Mainframe- IBM z9
- communication between mainframe and pheripheral is through VTAM (TCP/IP)
- output in que inside the main frame. Print using print support facility.
--Mainframe- IBM z9
