See attached image. Firmware is up to date and I downloaded the latest driver. I had an issue getting it to print single sided and had to go through CUPS to enable it. Is this a MAC problem?20160706_152748a.jpg
Mac Printing error on c454...OS10.11
Tags: None
Re: Mac Printing error on c454...OS10.11
Yes, it is a mac problem. you have to go into CUPS and disable double side printing.
You cant disable it in MAC driver and save it. Thats not work, i had seen it often enough.
But otherside, if you install a driver under Windows, you have allways to deselect double side printing
under default settings.
Reason is new (2008)EU-Order for saving paper.??? -
Ok.
Take the same document you are trying to print and instead of doing a print function, save it as a PDF and then print from the saved PDF. Sometimes when the document is re-compiled with Apple's Preview, it corrects some of these issues and allows you to print. If you were printing from a PC, you could re-compile with BullZip PDF printer.
REACH FOR THE STARS!!!
Konica Minolta Planetariums!
https://www.konicaminolta.com/planet...gma/index.htmlComment
I'm not that familiar with KM devices but it appears to me that the printer cannot interpret the print data. What print driver language are you using? If it's PostScript is PostScript installed on the printer?Comment
