Microsoft update KB3159398 breaks gpo printer mapping
  • dotdeas
    Senior Solution Consult
    • Aug 2015
    • 18
  • habik
    • 2013
    Re: Microsoft update KB3159398 breaks gpo printer mapping
    Byting on bits.
    Firmwares HERE
    • ApeosMan
      • Nov 2009
      • 183
      KB3170455 is another bastard of an update...
      • tonnerboy
        • May 2011
        • 212
        Did someone manage this update?
        One of my costumers are calling me with this issue. He tells me that it is related to the Digital Signature of the driver
        Can same one help me with it? He is using a Ricoh MP6000 PCL6 driver
        • rthonpm
          • Aug 2007
          • 2859
          Here's Microsoft's mitigation for this issue: https://support.microsoft.com/en-gb/kb/2307161 If it's a small customer you could just have them turn off Point and Print restrictions entirely.
          • amos.kaplan
            • Feb 2015
            • 19
            I had this one stop smb to folder...
            Security Update Capicom KB931906 2.1.0.2
            • tonnerboy
              • May 2011
              • 212
              Hi.
              This is not a smaller customer and change the group policy restrictions it's out of the question.
              This is related to the digital signature. How can I put a digital signature in printer driver?
              • rthonpm
                • Aug 2007
                • 2859
                Unless you have a digital signature recognised by Microsoft, you can't. Just have the customer change the GPO to allow point and print printing from their specific print servers if possible, or at least let them know that it's a Windows issue. Have you checked for a newer print driver as well?
                • emujo
                  • Jun 2009
                  • 3009
                  KM drivers are digitally signed, this update add something called "driver package aware". I just went through this with another customer. They were able to go onto the print server and manually change the setting on the driver to "package aware".
                  From Google...
                  This tweak will get your Canon, Sharp or KonicaMinolta printers up and running again by making the drivers Package Aware.
                  Edit the register on your print server(s). If you change the
                  value of the key PrinterDriverAttributes under
                  HKLM\System\CurrentControlSet\Control\Print\Enviro nments\Windowsx64\Drivers\...\Driver
                  name\ and restart the print server, you are able to make
                  Windows treat the driver as packaged, and it will install unattended
                  with gpo. The hex number has to be odd.
                  To keep the original settings for the printer driver and only
                  make it Package aware you should add 1 to the original value of
                  PrinterDriverAttributes. In my print environment the original attribute
                  had the value 4, so I changed it to 5 and that made it
                  Package aware. Different versions of the driver (and different vendors)
                  might need other values.
                  Restart server .
                  According to MS the 1 flag for PrinterDriverAttributes stands for
                  PRINTER_DRIVER_PACKAGE_AWARE. This will treat the driver as package
                  aware, which means a CAB package will be created, including the inf and
                  the catalog. The package will be installed through
                  setupapi.dll when installing the driver, validating that the catalog is
                  trusted, and that hashes for all files are included in the catalog.
                  BTW: This is not a Microsoft problem, but a printer vendor problem!
                  Two lines of code in the *.inf file will make the driver Package aware
                  and fix the problem properly! Solution for vendors posted by Microsoft
                  here: https://msdn.microsoft.com/en-us/library/windows/hardware/ff559698(v=vs.85).aspx
                  • tonnerboy
                    • May 2011
                    • 212
                    Ernujo, Thank you so much for your info. Learn a lot.
                    I saw that the Ricoh MP6000 PCL6 Driver for Universal Print is Package-Aware since Version 3.8.0.0.
                    I do not know if it will solve the problem of this patch (KB-3170455) because this version has been released a long time ago... I will wait for the reply from costumer.
                    Once again thank you so much.
                    • tonnerboy
                      • May 2011
                      • 212
                      Update:
                      Even though the PCL6 Driver for Universal Print for MP6000 is Package-Aware since Version 3.8.0.0Release Date: 18/05/2016.
                        • 37572
                        Update:
                        I my opinion, Universal Print drivers should only be used when you need to pool different models. Pooling requires that all printers in the pool use the same driver. I have a school district that recently updated their servers from Server 2008R2 to Server 2016. They have a MP 9001 and a MP C6501. Their IT service decided to use the Universal Print driver. Worked OK on their 64 bit computers once I showed them where to set their Used Code and Mailbox tray. The problem was that they have a number of 32 bit computers that could not print. When checking the one in the office, I found that there was no place the enter the user code because it was trying to use the Microsoft Point and Print driver. The IT service then tried to load the 32 bit driver as an additional driver and the server would not accept the 32 bit Universal driver as a compatible additional driver for the 64 bit. I gave them the machine specific drivers.
                        • tonnerboy
                          • May 2011
                          • 212
                          I agree with you 100%.
                          The attempt to use the PCL6 Driver for Universal Print was because it's more recente... and Package-Aware since Version 3.8.0.0. Even though it did not work...
