Disable USB printing Konica Minolta Bizhub C360
  • Timoteo82
    • 39
    Title pretty much explains it. I want to know if there is way to disable the usb printing feature on the bizhub C360. I need to keep public printing available just not through usb.
  • wseyller
    • Sep 2012
    • 1129
    Re: Disable USB printing Konica Minolta Bizhub C360
    Do you mean printing from USB memory stick or to a PC using USB port.
    To disable printing from USB stick
    Utility][Administrator Settings][System Settings][User Box Settings][External Memory Function Settings][Print Document]
    Select whether to allow users to print files from a USB memory.
    [ON] (Allow) is specified by default.
    If trying to disable print to PC via USB cable I'm not aware of any setting. But if user does not have admin privileges to their workstation then their is no way for them to install a driver with USB printing port.
    Sent from my Nexus 6P using Tapatalk
