Server 2012 R2 - pcounter XPR embedded - c220
  • joneze
    • Aug 2007
    • 128
    Hi,
    Bit of a long shot but has anyone had any issues embedding KM C220's with XPR embedded. It is only an issue on server 2012 device firmware is up to date, firewall is not an issue as c454 embedds no problem. Event log shows an error could not create tls / ssl secure channel.
    Sever is fully updated, and is a new clean install.
  • sparks45
    • Jun 2014
    • 25
    Re: Server 2012 R2 - pcounter XPR embedded - c220
    Has all the ssl settings been enabled on the device?
    • joneze
      • Aug 2007
      • 128
      Yes all SSL is setup, the machines embed fine on server 2008.
      • sparks45
        • Jun 2014
        • 25
        The C220's might need special firmware, worth double checking KM knowledge base for recommend level of firmware for Open API solutions.
        • joneze
          • Aug 2007
          • 128
          Thanks, found the issue. Turns out some recent MS updates block communication with the C220's
          Removed and now works fine.
