MP2501 scan OCR
  • tufbnme
    • 493
    MP2501 scan OCR
    I know very little about OCR but I have a customer with a MP2501 and wants to know about OCR scanning.
    Can anyone enlighten me?
    • 37459
    Re: MP2501 scan OCR
    I not certain if the 2501 supports embedded OCR. That function capability was introduced with 2553 I believe. Here a link to a Video nugget that might help. Type OCR into the search box.
    • tufbnme
      • 493
      Re: MP2501 scan OCR
      Thanks, that is very helpful and interesting. Funny how it is an option now when the older Ricohs 3245c etc had it as standard.
        • 37459
        Re: MP2501 scan OCR
        They have always been able to do so when using software on the computer. The new machines with the options can embed OCR text in the PDF. The only problem is that it can minutes to process the scanned data for each page. The document is not sent to the folder until all pages are processed. OCR software on a computer that uses TWAIN/WIA scanning can usually be considerably faster.
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
          Re: MP2501 scan OCR
          No way that the 3245 had embedded OCR, let alone as a standard. (OCR fonts, maybe.)
          Embedded OCR is quite new to Ricoh MFPs, only recently introduced.
          Like SlimSlob said, it can be painfully slow. In addition, on board OCR isn't very accurate, either.
          Good OCR needs to run as a PC application, and is not cheap, not to mention it can be a REAL resource hog.
          One solution is to have the MFP scan to a watched folder, then have the OCR application pick it up from there.
          • ruben
            The New Guy
            • Oct 2012
            • 1203
            Re: MP2501 scan OCR
            Google offer free OCR reading from within their Drive service. You need to import a scanner image, and open with Google Docs.
            (You can use Google Sync to automatically upload any scanned files.)
            Whether it is any good or not, I cannot say, asI haven't used it.
            • Brianneoe
              • May 2015
              • 318
              Re: MP2501 scan OCR
              Ricoh has a solution called PPDM 2016 that is a suite of Nuances OCR packages. The Omni page component will allow you to set up a bunch of SMB watch folders for different conversions,i.e. OCR to Word, Searchable pdfs and Excel. The nice thing about the searchable pdf conversion is that it will reduce the file size down a third after the conversion. This seems to be a big plus for Law firms that need to file electronically to the courts. I have a few Law firms that we install this on. One firm is using 3 windows 7 VM's because of the amount of scanning that they do. One each for the 3 6001 that they have. We create all of the scan folders at the W7 box and link them to the workstations and or a backend DM server.
              There are some settings that need to be tweaked when you deploy this solution. If the end users scans in 50 pages or so at a clip you will need to increase the time for when the program starts to act on the pdf.
              If you are a Ricoh direct or dealer with access to their TSC site you can download the solution and request a NFR key.
              Good luck..
              • KenB
                Geek Extraordinaire
                • Dec 2007
                • 3944
                Re: MP2501 scan OCR
                Keep in mind that any NFR key is for your own use only, and NOT to be given to a customer.
                Don't release that monster by breaking the rules.
                • qbert69
                  • Mar 2013
                  • 1152
                  Re: MP2501 scan OCR
                  Good luck..
                  THANKS!....I got my PPDM 2016 NFR Key and am gonna check it out! File Size is 2.3 GB....will be waiting awhile for it!
                  REACH FOR THE STARS!!!
                  Konica Minolta Planetariums!
