I'm here in Houston recovering from Ike. Our Building was only without power for a week no power surges, no damages. When we brought our network backup we have a Minolta Dialta Di250 with a PI-3500 Print Controller. It was using dhcp and worked fine from the day i started working here(2 years) to the day we powered our network back up after the outage. It was using the same IP address as one of our file servers (grabbed the IP before the other machine booted), anyways the printer was deleted from the server it was shard from then when trying to readd it won't connect properly. all ports and everything verified. Company recently upgraded from server 2000 to server 2003 any ideas? same issue on a Konica 7030(had other issues those were resolved). Also whenever i try to add a preshared printer to a computer that existed on the network previously it gives me "Windows cannot connect to the printer. Make sure that you have typed the name correctly, and that the printer is connected to the network." but if i add it \\server\printername it works fine. it shows up in active directory but gives the previous error when trying to add. if added manually prints fine.
Positive this is a network issue.
