Server 2008 showing printer offline
  • EDSNOW
    • 187
    As I am not a Windows server or IT person I am looking into any suggested solutions for a Kyocera MFP not showing online.
    It can be pinged ok and the Command Centre shows in the browser from the server, I tried to use the Kyocera driver on a workstation but IP address won't show.
    I think it has something to do with SNMP settings but not being an expert I am not sure.
    I do know the device prints as tested before bringing to the customer site. Brand new MFP TASkalfa 2552ci.
    Any input or suggestions greatly appreciated.
    Regards
    Ed Snow
    Edsnow@yos-wbm.com
  • tjvincent
    • 280
    Re: Server 2008 showing printer offline
    You could try disabling SNMP in printer properties, ports, configure port, uncheck the box called "SNMP Status Enabled"
    • 906
      • Mar 2017
      • 13
      Check to see if your IP / Port has a _1 after it. If it does, there's a duplicate and something else on your network has that IP as well.
      • EDSNOW
        • 187
        Thanks for the replies. I will follow up and advise the final resolution.
        Regards
        Ed in Whitehorse.
        • EDSNOW
          • 187
          FOLLOW UP
          FYI
          When I was at the customer location today upon arrival there were a couple of test sheets sitting on the machine from the IT person's server.
          I also tested the machine directly with a laptop and network cable as well as USB printing.
          Also while there the IT person sent another print job.
          I have asked if any settings had been changed at their network/server location and if I get a reply I will pass along.
          Thanks to all who viewed and the replies.
          Regards
          Ed
            • 30271
            Uncheck SNMP in port configuration,
            • Eresources
              • Nov 2011
              • 37
              SNMP will more than likely fix the issue. I've had this problem with HP switches mostly but there is some gear out there which is based on or has the same hardware on the inside as the HP, they also have the issue.
              *NOTE* This also only occurs in Windows Server 2008 and upwards.
