Server 2012 r2 with Gmail
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    Greetings,
    OK, this is a bit of a weird one.
    I spent about 4 hours on it today doing tons of research and experimentation, but no dice.
    I have a customer with a document management solution that runs on Server 2012 r2.
    They use Gmail.
    Gmail can both send and receive when using I.E. or Chrome on the server.
    If I right click a file and select "Send to Email", I get a message that there is no default email setting in Control Panel.
    Any preference as to what email app (Thunderbird, Opera, etc...) that will "front end" Gmail, and still play nice with Server 2012?
    The application can't interface directly with Gmail as is; it must use the default email app on the server.
    I don't want to just start trying different email apps, as this just recently became a production server.
    Thanks!
  • ldharnden
    • Apr 2011
    • 47
    Re: Server 2012 r2 with Gmail
    Gmail and Thunderbird have always worked well for me.
    • faxman28
      • 435
      needs to be email software like Outlook (MAPI compliant) not web based like Gmail. You can install Outlook and have Outlook access Gmail.
      check out MAPI for GMAIL , just saw it on web, MAPI4GMAIL.com
      • faxman28
        • 435
        needs to be email program loaded on pc/server like outlook(MAPI compliant) . GMAIL is web based. also you can try mapi4gmail.com,
          • 37508
          Mozilla Thunderbird is a PC/Server based email program. You will have to configure the gmail to allow POP/IMAP. You may have to turn ON "Access for less secure app" for some Desktop mail clients like Microsoft Outlook and Mozilla Thunderbird.
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            Thanks, guys.
            I appreciate the answers.
            One thing I was considering was the Windows Mail app (which disappeared with Server 2008).
            It can be added by enabling the Windows Desktop Experience, then going to the App Store to download the the Mail App.
            I found instructions as to how to get it to work with Gmail.
            I'm trying to keep it an "all Microsoft solution" if possible, so that the customer can never come back with "That's a third party app. We never approved it. It's evil and must be destroyed."
            • ldharnden
              • Apr 2011
              • 47
              Originally posted by KenB
              Thanks, guys.
              That is a GREAT idea o keep it in the family. Good luck!
              • CanonSco
                Man About Town
                • Jul 2010
                • 368
                MS "MAIL" is making a resurgence in Windows 10. Was one of the few things I liked in the previews of Vista.
                Yes, I am a nerd.
                Gaming PC - check. Raspberry Pi - Check. Custom ROM on phone - check. Thick glasses - check.
                • rthonpm
                  • Aug 2007
                  • 2858
                  Their 'server' app sounds like it's built for a glorified desktop rather than one built for a system that should be running completely headless with no-one regularly logging into it. What's the name of the software? Is it possible that it's actually built for a workstation or kiosk as opposed to a server? Is there a web interface for it that can do most of the work from a remote machine?
                  Once you start adding in additional software like a mail client it becomes one more thing to get patched, and as a rule servers should have as little client level software on them as possible. Granted, that's not always possible but it is something to consider. A lot of business customers are more than happy to buy software without ever taking into account whether they, or the salesweasel, is actually giving them what they really need.
                  • pebkac
                    • Oct 2014
                    • 36
                    I agree with rthonpm. The whole thing sounds fishy. A document management system that relies on the default mail client is just broken. It doesn't make sense. Even PowerShell has an SMTP client cmdlet.
                    Does this software not support email at all, or is there some kind of problem specific to Gmail?
                    And what's the name of this software, so that we can laugh at it?
                    • KenB
                      Geek Extraordinaire
                      • Dec 2007
                      • 3944
                      I'm not going to divulge the name of the software, but I will say that it is a very well known and well respected ECM application.
                      Nothing small time about it; a typical installation runs between $50k and $100k, some are much more.
                      The desktop client currently can only use MAPI compliant email, but I have found that since my original post, that the web client works just fine with Gmail.
                      The desktop client (or the old school term of "thick client", if you will), is in the process of ultimately being phased out. This is actually a very good thing, as there is no maintenance involved in making sure the users have the latest version, patch, etc...
                      The application itself is running on Server 2012, and all the users' desktops are on Windows 10 64 bit. The customer is using Gmail, without any additional client. They do have Outlook available, ( as they have MS Office), and IT will set up any user with Outlook / Gmail should they require it.
                      As the only PC I have access to is the Server 2012, I was hoping to be able to send from it if need be. I now know that I can use the web client if I have to.
