Usefull Cheep/free software used
  • Geo
    • 662
    Hi All
    I thought it may be useful for all us suffering techs to share what programs are being used to make our lives a little less stressful.
    Thanks much..
    Cheers...
  • habik
    • 2013
    Re: Usefull Cheep/free software used
    MS Windows [emoji14]
    Sent from my GT-I9300 using Tapatalk
    Firmwares HERE
    • NeoMatrix
      Senior Tech.
      • 3513
      haha... I believe he said useful software...
      • D_L_P
        Self Employed
        • Oct 2009
        • 1196
        Foxit pdf viewer has been a lifesaver several times latley for Pdf printing issues. Use foxit and the pdf prints how it should, showing the mfp isn't the issue.
        A lot of my customers seem to like irfanviewer. It's a free photoeditor, great for resizing images to post on copytechnet. What they like about it though is that it shows up as a printer so they can print/convert any file to a pdf. Works great for those web based programs that don't like to print. Print with irfanviewer, save it as a pdf, which then prints fine.
        Not sure if it's still available but kyocera made an undelete utility (kmundelete) that was good for uninstalling print drivers.
        • CanonSco
          Man About Town
          • Jul 2010
          • 368
          I still use kmundelete. Great little app.
          Have used Irfanviewer when MS Photoviewer is causing issues.
          Foxit is great, use it regularly.
          Yes, I am a nerd.
          Gaming PC - check. Raspberry Pi - Check. Custom ROM on phone - check. Thick glasses - check.
          • Ottawatech
            • Feb 2015
            • 63
            Teracopy - TeraCopy for Windows - Code Sector
            Much, much faster than windows file copy/move.
            Nothing works quite so well that I can't totally disable it by trying to make it a little better.
            • mansart
              • 852
              Angry IP Scanner
              • giddyupngo
                • Oct 2014
                • 109
                Re: Usefull Cheap/free software used
                (oops, just realized this was posted in connectivity, none of these are connectivity related)
                I use a few smartphone apps that are helpful.
                To check humidity, I use "Galaxy Sensors", it is phone specific, but there are lots of these, so you can probably find one you like. Sometimes if there is jamming, you can check if there is high or low humidity in the environment, which could cause it.
                The other is "FaxBurner" There is a free version that gives you a free Toll Free number. You can fax out from the copier to the app 25 times per month. The fax shows up in your app and in your email as a digital PDF. This takes around 10 to 15 minutes. This is useful for checking quality, seeing if the fax goes through etc. You can fax from the app to your machine 5 times "lifetime". You can obviously do more if you upgrade.
                Occasionally we will take video with our phones in slow motion to try to unravel a jamming problem. This is probably standard in many phones, there may be an app too.
                Hope this helps someone.
                  • 37514
                  Never heard of Irfanviewer, so I decided to search it. All that came up was Irfanview which I have used for years. It is much more than a viewer. It is a very versatile program, especially when used with all of the available plugins, including ghostscript. It can open almost any image or document file. It can save a file in whatever format you want. You can take a screen shot, paste it to Irfanview, crop off unwanted portions of the page and save the result.
                  • Ratchet2501
                    • Mar 2017
                    • 206
                    I'm still a fan of Piriform. Ccleaner, defraggler and such. Call me crazy but thus far theyve been useful even in windows 10
                    • rthonpm
                      • Aug 2007
                      • 2858
                      7-Zip. It can extract just about any kind of compressed file, including exe's and ISO's. It's also very helpful for things like HP print drivers where you don't need all of the additional bloatware. Just extract the contents of the driver download and when installing the printer in Windows, just point the printer install menu at the folder you've extracted the driver files to and magically you've got a printer installed without taking several hours.
                      Irfanview, which was already mentioned.
                      PuTTy, for telnet and SSH
                      • Geo
                        • 662
                        Hi All
                        Thanks for all the help and suggestions...All good and useful stuff. ...I sure these programs will help a lot of people and solve a lot of headaches.....
                        P.S..
                        Any more
                        P.P.S .
                        Thanks again..
                        • NeoMatrix
                          Senior Tech.
                          • 3513
                          Originally posted by Geo
                          Hi All
                          P.S..
                          Any more
                          P.P.S .
                          Thanks again..
                          You may like to search the CTN forums. There are some old posts with the similar requests.
                          Here is one you might like:
                          hhttp://www.copytechnet.com/forums/connectivity/97276-all-one-i-t-tech-software-3.html
                          http://www.copytechnet.com/forums/co...oftware-3.html
                          • allan
                            RTFM!!
                            • 5462
                            Note++ and
                            Cyberduck
                            Whatever
                              • 8207
                              I often recommend to customers the free version of "Glary Utilities" to help clean up slow computers.
