Sharp MX- 503 connectivity issue
  • xring1958
    • 166
    OK Guys here is a weird one that I am posting in Sharpsection and Connectivity section.
    We have a Sharp MX-503 that we installed about six monthsago that immediately had connectivity issues. The customers IT departmentseemed to solve it but now claims it has been an ongoing issue.
    Their IP Range is kind of weird like 172.16.41.55 as anexample. When we enter an IP address that has been used for a previous MFP we cannotping the address or connect to the machines imbedded web page. If we allow DHCPto select the address we can ping and connect to web page. If we make that a static address the machinewill stay connected until it is either turned off or goes into sleep mode. Itwill usually not be connected by next morning but not always.
    • 30271
    Re: Sharp MX- 503 connectivity issue
    Did they do a DHCP mac address reservation for the ip address?
    or you may have a device grabbing the same ip address. ie cell phones
    did you ping the ip address it had?
      • 37520
      This sounds like a problem that is found on high end stacked routers and switches. The first an IP address is used, either by DHCP or manually configured, the network MAC,media access control, address is stored and in the future, that IP address is reserved to that MAC address. Any other device, with a different MAC, that tries to use the same IP address will be locked out of the network.
      • techwurk
        • 127
        This would be using a static IP within the DHCP range, which should not be done. There is also a mask range for IPs somewhere but can't remember where
        When I started servicing copiers they used toaster ovens for fusers.....I'm old
        • bburp
          • May 2016
          • 11
          I don't know why my answer seems to work but is has worked for 3 small kyocera's and now a SHARP MX-5001. I inserted a small 4 port switch in the network line at the MFP. It now prints and I can connect to webpage. One other thing I have found with kyrocera's is to turn off snmp in the driver, the mfp's need a reboot to reconnect with snmp turned on in the driver.
