Job Centro is unable to connect to IC605 on KonicaMinolta C3070L
  • jrf
    • 142
    Hi
    We have just set up a C3070L with an KM IC605
    Job Centro is not able to find any printer.
    We get an error 503 Service unavailable if we try and browse to it.
    Firmware is up to latest.
    Any ideas please
  • peter42
    • Jan 2012
    • 110
    Re: Job Centro is unable to connect to IC605 on KonicaMinolta C3070L
    print Fiery configuration sheet
    find ip-adress of Fiery
    Set your laptop to same range of ip
    connect laptop to fiery with ethernetcable
    Log into webinterface of fiery
    Go to Setup
    Use Password Fiery.1
    Set Networksettings to actual configuration of existing network.
    Reboot Fiery and machine.
    • jrf
      • 142
      Go to Setup
      Thanks for reply, however the IC605 is not a fiery, it is a KM controller.
      but I got it sorted , browse to ip and add :30083 to end of ip address.
      There is also a little configuring to be done under network settings.
      • Olatunji
        • Jan 2022
        • 1
        Hello, Please what are the "little configuring that needs to be done.
