canon smb scan to file
  • Jerrygbs
    • Dec 2008
    • 193
    It seem that lately on a lot of my canons when I go to set up scan to file, when I browse I cant see the network and if I do I cant see the computer or the file. The same is happening when I host search, has windows updated securities or something else? I'm just a toner jockey and the customers IT people either won't or can't help. I either get check server or no response . Any help is appreciated
  • rthonpm
    • Aug 2007
    • 2859
    Re: canon smb scan to file
    It sounds like the customer has disabled SMB1, a very old version of the protocol for file sharing which is considered insecure. You may want to check if there's firmware available to let the machine scan using SMB2 or SMB3. In newer versions of Windows 10, SMB1 is disabled automatically.
    • CLC700
      • Oct 2017
      • 1
      Is there any way to allow smb1 on windows 10 ? I tried this setting: [Control Panel > Programs and Features > Turn Windows Features on or off > check or uncheck the box for "SMB 1.0/CIFS File Sharing Support"] but did not succeed. Scanning to file did not work. I know there are special firmware released, but not all older mashines gets it.
      Maybe someone has found a way to scan to file without firmware update, and is willing to share.
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5015
        Canon model? Hope not CLC 700.
        • petermays
          • Mar 2017
          • 91
          hi
          on pc in run type
          windows powershell
          let window open then type
          Get-SmbServerConfiguration
          you can see there if smb1 port is blocked and yes if its a newer generation canon you should get "special firmware" so it opens smb2
          • guitar9199
            • Sep 2016
            • 1100
            To try and browse the network and "find" the copier, first thing you need to do is check Control Panel>Network Connections, Right click>Properties. Find the IPv4 protocol and click the Properties button, then click "Advanced". Go to the WINS tab, and change it to "NetBIOS over TCP/IP". The default "Over DHCP" configuration won't let you browse to it from the copier.
            I had one I fought for 3 days before I discovered THAT little nugget!!
            Otherwise, your standard SMB setup. Same Workgroup, correct DNS settings, making sure the Firewall on the PC is set up for "Allow" on File and Printer Sharing and Network Discovery (NB).
            Good luck.... I know they can be frustrating! ... The copiers too!
              due to malware and viruses ... SMB1 is turned off in Win10. DO NOT TURN ON SMB1. if that company gets hit with malware or even ransom ware, then your company could be held legally libel for any damages incurred.
