Spooled holding temp files
  • CleanTheSlitGlass
    • May 2018
    • 19
    • 30550
    Re: Spooled holding temp files
    Install new driver and set it up correctly.
    Ipaddress
    port to raw 9100
    uncheck snmp
    emulation to pcl5e
    uncheck auto configure
    do not install the mister happy status monitor
    How many workstation just set it up on local workstation and test not on there server
    • CleanTheSlitGlass
      • May 2018
      • 19
      Ipaddress
      port to raw 9100
      uncheck snmp
      emulation to pcl5e
        • 30550
        If they have not installed driver do a clean install new driver and new printer. Do not just update there driver to the kx driver start with a fresh driver.
        • copywiz
          • Nov 2015
          • 14
          Have similar issue but wanted to try firmware upgrade. I can't find the file online or don't know kyocera terms. Where do I find it?
          Sent from my SM-G900R4 using Tapatalk
            • 30550
            Firmware you would need a tech login
            Firmware is very very rarely the issue for resolving print issue problems
            usually incorrect driver or configuration is the problem
            Printer drivers are free from the Kyocera download center here's the link
            Home
            • CleanTheSlitGlass
              • May 2018
              • 19
              Will do, thanks man
              • NeoMatrix
                Senior Tech.
                • 3513
                Try deleting all the corrupt files in the windows spooler directory on the offending PC.
                Here is a link to a batch file that automatically deletes all the corrupt spooler files for you.
                htttp://www.copytechnet.com/forums/connectivity/97276-all-one-i-t-tech-software.html#post561092
                http://www.copytechnet.com/forums/co...tml#post561092
