Printer web interface disabled
  • mascan42
    • Oct 2008
    • 480
    I'm working on a Bizhub 3622 (Lexmark MX321) that has the web interface seemingly disabled (IP address set as 0.0.0.0 as per customer instructions) and because of an incorrect setting, I can't get into admin mode to change it. Is it possible to connect to this via hostname or some other method? I'm probably going to be using my laptop and crossover cable.
  • qbert69
    • Mar 2013
    • 1152
    Re: Printer web interface disabled
    You can't get into admin mode directly on the machine itself and manually set an IP Address??? Why is the IP Address set to 0.0.0.0 ???...[emoji848]
    Sent from my SM-N950U1 using Tapatalk
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
    • mascan42
      • Oct 2008
      • 480
      The customer wanted it set that way to disable networking (copier & fax only). And I must have checked off the wrong box somewhere because I can't access the admin mode from the control panel.
      • qbert69
        • Mar 2013
        • 1152
        You'll probably have to go into meter->service mode to reset & clear all system settings. If I remember correctly, it is a type of memory clear, like a revert to Factory default settings. Good Luck!!![emoji41]
        • mascan42
          • Oct 2008
          • 480
          Unfortunately that also requires a login that it won't allow. "No login method configured" is the message I get when trying to enter admin or service modes.
          But I do know I can login via the web interface if there's some other way to access it. If the static IP is 0.0.0.0, can I still connect via hostname?
          • qbert69
            • Mar 2013
            • 1152
            What does it hurt to try???[emoji848]...as long as you know what the hostname is!!!...and with a crossover cable.
            • qbert69
              • Mar 2013
              • 1152
              Can you *NOT* login to service mode through the meter details method and reset to factory settings?![emoji848]
              • mascan42
                • Oct 2008
                • 480
                Nope. "No login method configured." I'm locked out of pretty much everything.
                I may try going back and accessing it via host name, but I just wanted to see if it's even possible first.
                  • 22804
                  you will never be able to see the device in a network that has ANY IP range other than 0.0.0.0!
                  their network is somewhere in the common ranges 192.XXX.XXX or a 010.XXX.XXX.XXX more than likely.
                  hook your laptop up to machine w. crossover.. set machine to 192.168.1.1 set laptop up to 192.168.1.2 ( you may have to reboot once changes saved. )
                  go to command line... do your "ping" command... of results good.. go to WIM and try to login as admin.
                  if all good ( print reports ) go to customer and inform them the printer MUST be set in an active IP Range for their network. Then set up either account codes on copier or set printer rights... any passwords used.. write down make copy .. 1 to you 1 to IT
                  • qbert69
                    • Mar 2013
                    • 1152
                    Hey Phil B.....Apparently you didn't read the part where it says he can't login to admin mode to change/ add the IP ADDRESS!!![emoji15]
                      • 22804
                      yes I DID! BUT if the IP's don't match he WON"T be able to WIM in
                      he is having a NETWORK issue.. so ALL admins functions won't be able thru NETWORK.... I have seen on Kons and Kyro and Xerox that same issue... he DIDN'T mention if he can BOOT the print/copy INTO service mode tho!
                      • qbert69
                        • Mar 2013
                        • 1152
                        Correct. Thanks for the clarification!!![emoji16][emoji1303]
                        • D_L_P
                          Self Employed
                          • Oct 2009
                          • 1196
                          If you know the MAC address you can get around the 0.0.0.0 with an arp command.
                          1. Assign a static IP to your laptop such as 192.168.0.10.
                          2. Connect to the Bizhub with an ethernet cable.
                          3. Open a command prompt.
                          4. Type " ARP -s 192.168.0.20 (MAC address of the Bizhub)".
                          So it would look like this= arp -s 192.168.0.20 00-00-00-00-00-00
                          Your computer will now be able to web into 192.168.0.20
