email not working
  • richs
    • Nov 2008
    • 266
    email not working
    I replaced the main pcb on an Oki ES8473 to solve an error problem.After replacement all settings had to be re-input.They use office 365 to send email and I have checked all settings with the other machine they have there. They cant email.It errors out and seems to indicate that the machine can not find the server.I did change setting to use gmail and it worked.They want their office 365 account to work.
  • mansart
    • 855
    Re: email not working
    TT-063015_2.PDF
    This is a Sharp bulletin regarding Office365 and email...... may be applicable to your problem
      • 37628
      The replacement board might not be at the same firmware level.
      • richs
        • Nov 2008
        • 266
        Last time I did a firmware on this machine it failed and then I had to replace the main pcb.Also I dont see anything related to email when going over the documents.Like I said....works with gmail thou.I did ask their IT person to reboot all routers and switches when he can.(probably he wont)
        • richs
          • Nov 2008
          • 266
          Got it working.Did a factory reset and re input settings.
