Shrink to fit vs Shrinking 50%
  • Doug James
    • Jan 2012
    • 935
    (Using an adobe format) I have a customer that when he shrinks his 22x34 document by 50% and prints on 11x17 paper it prints just fine. When he checks the "print to fit" box it it shrinks the document even more where it has a 3 or so centimeter blank outer edge. This is important because he wants to shrink other "to scale" documents of different original sizes to 11x17 paper.
  • tsbservice
    Field tech
    • 8007
    Re: Shrink to fit vs Shrinking 50%
    Wait...there is no no manufacturer nor model?! What about print driver?
    Well, atleast it's is in Connectivity sub-forum
    • NeoMatrix
      Senior Tech.
      • 3513
      Its a software issue not a printer driver or machine fault.
      Set up a printer "custom page layout" in the design software.
      Eg. Set physical Paper size, borders,margins,tabs,gutter,header,footer etc...
      Switch to the "custom page layout" required when printing off each custom job.
      HTH
      • Doug James
        • Jan 2012
        • 935
        HTH
        Thanks so much !! We will give that a shot !!
          • 37469
          Edge to edge print in Adobe and driver.
