setting up printing on CHROMBOOKS
  • fshead
    • 2378
    HI
    i tried to get a chromebook to print to a ricoh mpc4503 and could not get the app from their site to work.
    Machines print jibberish and keeps printing till i do copier print job reset
    Are these cheap laptops just too cheap to do normal printing.
    I didnt spend a lot of time but did muck wth it a bit to no avail..
  • qbert69
    • Mar 2013
    • 1152
    Re: setting up printing on CHROMBOOKS
    Originally posted by fshead
    HI
    Chromebook probably uses a postscript print driver....does the ricoh have the postscript option installed???[emoji848]
    Sent from my SM-N950U1 using Tapatalk
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
    • JR2ALTA
      • Feb 2010
      • 2033
      Try logging into Chrome (with your Google account) on a Windows PC.
      Type "chrome://devices" in the URL. Setup a cloud printer that way, and it should be there and work when logging in to your Google account via a Chromebook.
      • fshead
        • 2378
        thanks
        the chromebook is a sales mans at a real estate office i service so it wouldnt be my laptop.
        I guess if he is there i can use a windows based pc at site and test it.
        I get this is the future technology $199 units with barebones options.
        • Brianneoe
          • May 2015
          • 322
          Did you purchase the google print app from Ricoh {70 USD} and load it onto the MFP? If not you will need it to print through google cloud print. The instructions are quite confusing but I was able to get it working on a few chrome books.
          • fshead
            • 2378
            nah
            i went there as the one saleguy tried to print to a mpc4503 i service and it kept printing garbage endlessly.
            I showed them how to clear print cue and told the salesguy not to print wth his Chromebook till i get some answers.
            I doubt he will want to spend $70 to print..
            i told him about the thunb drive option.
            I mucked wth his CB for 30 mins and like you said it was confusing.
            • guitar9199
              • Sep 2016
              • 1100
              RICOH Print for Chrome - Chrome Web Store
              • SIN3R6Y
                • Feb 2019
                • 12
                Been down this rabbit hole...
                Your best bet is setting up a linux or windows server appliance running google cloud print...
                GitHub - google/cloud-print-connector: Google Cloud Print Connector
                From there if you have any fancy network gear (like cisco / switches or AP's) you have to go in and enable multicast traffic so that the chromebooks can see the cloud print server.
                If all goes well, you will see the printers magically show up in chrome.
                • Ceechtay
                  • Sep 2011
                  • 158
                  You can also try printing directly to the copier from the Chromebook. You won't have to add Google Cloud Print to the MFP to do this.
                  I made a quick PDF with instructions: Setting up a Chromebook for Direct Printing.pdf
                  If the exact model is not listed, you usually can get away with using a similar model's print driver.
                  • mincopier
                    • Dec 2015
                    • 289
                    Look up "Google cloud print classic". Basically a windows PC is setup as a "Print Server". The printer is set up shared through a Gmail account to Chromebook users. As long as the PC is on they should be able to print.
                    • leo34staffs
                      copierman
                      • Aug 2007
                      • 503
                      I made a quick PDF with instructions: [ATTACH]41653[/ATTACH]
                      Great little help sheet.. thanks
                      Is it possible to have user authentication enabled and to print from chrome book??
                      I recently setup a machine to default use an account with black and white but not colour until a code was entered in the driver or on the copier itself.
                      But when sending from a Chromebook, nothing comes out unless authentication is disabled. Is there a way around this so that Chromebooks can print and preferably just in black and white?? The copier is a Sharp mx4140
                      Networking skills are advantageous but use of a 3m vacuum cleaner is essential
