Windows Server 2012R2 Print Queue
  • keithxxiii
    Just a tech
    • Nov 2014
    • 469
    Hi Folks,
    Just wanna ask if you have encountered a requirement to hide the document names in print queue while printing from a shared printer.
    From the end user's pc, select see whats printing and while keeping it opened, you'll notice the print documents comes and depending on the spool size, it disappears eventually.
    Is there a feature to disable this?
    Aye! Cut the crap
  • rthonpm
    • Aug 2007
    • 2854
    Re: Windows Server 2012R2 Print Queue
    Only if the device has a secure print function. Many Ricoh devices offer a secure print option that won't allow the document to print until a code is entered at the machine. It will also obscure the file name and username of the job. I'm sure other manufacturers offer something similar.
    • keithxxiii
      Just a tech
      • Nov 2014
      • 469
      Thanks for the info. Yes, most ricoh devices offer secure print. But the client's requirements is from the window's pc itself.
      Referring to the image below, for a shared print queue, the user will be able to see the spooled documents.
      Is there a way that a user can only see his/her document?
      BR
      Aye! Cut the crap
      • rthonpm
        • Aug 2007
        • 2854
        There's no real way from Windows to accomplish this. By default, any authenticated user has permissions to print, which grants them the ability to see the print queue and other jobs in it. They can't edit or manage them in any way by default. The only possible ways to limit it would be either direct IP printing (bad), or to limit who has access to the print queue on the server, which can cause a bit of confusion.
        • D_L_P
          Self Employed
          • Oct 2009
          • 1196
          Originally posted by keithxxiii
          Hi Folks,
          Is the render jobs on client computers selected?
          • rthonpm
            • Aug 2007
            • 2854
            [ATTACH=CONFIG]41505[/ATTACH]
            That will still send the information across with the job when it hits the shared queue. All that determines is where the translation from the file to PDL is performed.
            • NeoMatrix
              Senior Tech.
              • 3513
              Windows hidden files:
              In a CMD window the command to hide files is Attrib.exe
              Example:
              attrib +h mytest.txt
              The above command will only work if the Explorer GUI is not set to "Show hidden files,folders and drives."
              Otherwise the above attrib command is redundant.
              You could try creating multiple print drivers or share names that point to the same printer.
              Allocate a different share name to each individual person...
              Not sure how this would work out though...
              A powershell or VB script might create another solution...
              • Kimi
                • Feb 2018
                • 105
                Looks like a sales lead for MPS..
                I am not aware of how to resolve this otherwise.
                • tsbservice
                  Field tech
                  • 8016
                  Quote from here:
                  PaperCut KB | Hide Document Names on Windows Printers
                  • keithxxiii
                    Just a tech
                    • Nov 2014
                    • 469
                    It is indeed. The OEM visited the customer's site together with their "MPS Executive" and has told them that it is possible to hide the documents file names. I as a partner was left blank when we had a meeting with the customer as they were requesting for an expansion of the solution.
                    I'm almost to the point of letting it go and move on.
                    Aye! Cut the crap
                    • keithxxiii
                      Just a tech
                      • Nov 2014
                      • 469
                      Most likely a VB Script or a powershell command could fix this as what neo has said. Need to contact our MCSEs or Must Call Someone Else.
                      Aye! Cut the crap
