RICOH MP-2501 L
  • Polo-022
    • Sep 2007
    • 486
    RICOH MP-2501 L
    Machine has only a USB port and it is not recognized
    as a printer even if i installed it at another pc or laptop.
    Is this a damaged USB port or a BICU board, is it a blockage
    on it's own logic?
    Searching service manual i didn't find anything to restore logic,
    does anyone has a good suggestion?
    Thanks for any input.
    MP 2501L uses DDST driver...
    Re: RICOH MP-2501 L
    on it's own logic?
    Thanks for any input.MP 2501L uses DDST driver...
    well looking at the specs for this.. there is NO USB listed for print nor net.. those MIGHT have been for SERVICE only
    MP 2501L Specifications | Ricoh Asia Pacific
    • Polo-022
      • Sep 2007
      • 486
      Re: RICOH MP-2501 L
      Thanks Phil, this is not a standard photocopier only,
      it prints and scans as well.
        Re: RICOH MP-2501 L
        Oky fine.. does it support USB and if so has that port been activated? Not a lot of info provided
        • Polo-022
          • Sep 2007
          • 486
          Re: RICOH MP-2501 L
          Usb port is activated as default from the factory and through
          this port client could print. But suddenly it stopped to print and he called me
          to isolate the problem. SP settings have been checked, i can't find something suspicious!!
          • tsbservice
            Field tech
            • 8064
            Re: RICOH MP-2501 L
            Don't know this model but i have seen lot of damaged USB/NIC ports on different models. Worst case port is a part of main board, sometimes if you're lucky they are dedicated.
              • 37628
              Re: RICOH MP-2501 L
              Did it stop printing immediately following a Windows update? Most computers have multiple USB ports. Did someone inadvertently disconnect the USB cable and reconnect it to the wrong port like maybe janitorial service?
              • Polo-022
                • Sep 2007
                • 486
                Re: RICOH MP-2501 L
                May be yes, may be no...things are that i have never faced a
                damaged USB port. Well, i checked (plugs in & out) GDI Basic Board which is very expensive, BICU too.
                I use to have always such a problem with the same client, so
                i suggested a network printer as a cheap solution.
                Thanks again, i appreciate your help.
                • sturmtrooper
                  Copier Combobulator
                  • May 2016
                  • 587
                  Re: RICOH MP-2501 L
                  If you think the USB port is damaged you can always desolder it and solder on a new one like this
                  USB Female Type B Connector - PRT-00139 - SparkFun Electronics
                  A hot air station would make it easier but even with a standard soldering iron you could remove it. Much cheaper than a new board.
                  Now before doing that have you tried printing to it over USB from another computer or a laptop? I'd try that first.
                  • Polo-022
                    • Sep 2007
                    • 486
                    Re: RICOH MP-2501 L
                    Not so easy to destroy a USB Type B connector and how to diagnose that it's the connector faulty...
                    read my first post please, to answer the question what i have done so far...Thanks s/trooper
