scan to email fail
  • vigour
    • Aug 2010
    • 1038
    scan to email fail
    Unable to set up scan to email on a Samsung 8128.I inserted 2 different known email addresses and login credentials, but the self test fails.
    This was working at a hotel until the machine lost the smpt server info. I have seen hat before on this model.
    Putting the network cable from the copier into my laptop brings up a sign in page. Is this possibly what is preventing the copier from sending the test.
  • mincopier
    • Dec 2015
    • 289
    Re: scan to email fail
    Very possible. Sounds like the machine is connected to the public side of the network. It needs an authentication for the machine, usually laptop, to sign in to be allowed to get network traffic. Similar to an LDAP but not as secure. the trick would be to create your own wireless network bypassing the hotel network.
      • 30139
      Would need more information? DNS correct? Gateway correct? too many unknown's need more info
      • vigour
        • Aug 2010
        • 1038
        machine is using the DNS and GATEWAY picked up by DHCP.
        It worked before the smtp got wiped out.
        I have seen this model lose its smtp mysteriously before
        • peter42
          • Jan 2012
          • 110
          Did machine got DHCP info now?
          Print OK?
          Webside of machine OK?
          only SMTP Error?
          Then check
          Port number 25, 465, 587.
          TLS stuff
          have mail from provider about changes read?
          Password, security change(port number) etc...
          • vigour
            • Aug 2010
            • 1038
            Machine prints
            Website is fine
            DHCP works
            As said at the beginning It failed when I input the info for our gmail account we use for testing, same when I input my own gmail info
              • 30139
              Your assuming TOO much
              do and ipconfig /all and set it up manually Post a screen shot of settings
              add 8.8.8.8 as second or third DNS setting
