Mac OS Mojave job accounting
  • Scottb
    • Apr 2013
    • 306
    i have a customer with a Kyocera 3051. they got a new employee and this version of mac has Mojave and the job accounting only shows preset numbers...which are not even close the what everyone else is using. Is there a way to specify a specific accounting number, and if so how.
  • qbert69
    • Mar 2013
    • 1152
    Re: Mac OS Mojave job accounting
    Did you go into CUPS interface in Safari, localhost:631 to see if you can make a setting change there???[emoji848]
    Sent from my SM-N950U1 using Tapatalk
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
    • Scottb
      • Apr 2013
      • 306
      I have not and by the looks of it I have learned something new today...
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        Good call.
        BTW...You MUST use Safari. AFAIK, no other browser (Chrome, Firefox, etc...) will work, although I've never personally tried them to access CUPS on a Mac.
        • qbert69
          • Mar 2013
          • 1152
          Originally posted by KenB
          Good call.
          Correct! Safari is an Apple product is "hooked" into the OS. If CUPS isn't enabled, it will have to be enabled through the Terminal app/CLI.[emoji41]
          • mincopier
            • Dec 2015
            • 289
            Try configuring the account codes in Chrome, Notes, or MS Word. Set as a preset for B&W and Color and should be good. Some print drivers do not play properly with Safari on the newer Mac OS's.
            I myself have never tried setting up codes through CUPS.
            • qbert69
              • Mar 2013
              • 1152
              Ummm...CUPS--Common Unix Printing System (server) is the CORE management system for printers/drivers on all *nix OS's...all printing defaults get pushed to other programs. Apple has made it so you *HAVE TO* enter an admin password to modify printing defaults in CUPS!!![emoji41]
              • Scottb
                • Apr 2013
                • 306
                Thanks for the information guys
                • Brianneoe
                  • May 2015
                  • 322
                  Just checked my MAC driver for a C3551ci running on Mojave. The latest driver Version 4.0 has a "print panel" option that will allow you to set different Account codes under the "Job" settings. If you do use this Driver, make sure you remove the old version as per Kyocera.
                  Good luck
                  • keithxxiii
                    Just a tech
                    • Nov 2014
                    • 469
                    The latest printer driver for ricoh says "the user ID specified in the driver user interface might not be reflected unless the user interface is opened through specific applications".
                    Usually when we setup user code authentication, it is configured on the printing preferences. Now with this new OS, that feature is missing.
                    Aye! Cut the crap
                    • mincopier
                      • Dec 2015
                      • 289
                      I do know what CUPS is. I use a MAC everyday. I just never tried configuring with CUPS. I'm just cautious about using terminal on a customer's computer.
                      I have also found it to be convenient to the customer by creating "presets" when I input the "User Code". Yes finding the location that particular print driver wants the code inputted can be a hassle compared to being in the same place each time in CUPS.
                      Do you have specific directions on the "User Code" placement within CUPS? I understand how to get in but others may not.
                      • qbert69
                        • Mar 2013
                        • 1152
                        Are you a user or are you a USER!!!
                        cupsctl webinterface=yes - Google Search
                        Permanently set printer User Code - Lanie… - Apple Community
                        [emoji41]
                        • Brianneoe
                          • May 2015
                          • 322
                          Check that your using the latest PPD for that MAC from the Ricoh site. If your configuring a Savin or another RFG brand machine make sure your using that brands PPD.It makes a difference. If you let the MAC configure the driver without downloading the manufactures PPD you will not have all the options available. I use the IP setting plus the HP Jetdirect Protocol when I set up MACs to print. I checked a IMC 4500 and found the settings under "job log".Same place as the other RFG PPDs that I have tested/set-up.
                          Good luck
                            • 30291
                            Newer Kyocera MAC driver are setup like Windows KX driver interface. under Job accounting you should have a choice use specific code or from a list.
