RJ-45 loopback tool
  • tonerhead
    • Sep 2009
    • 582
    RJ-45 loopback tool
    I've seen the videos, etc. You know the ones where they plug the tool into a switch, laptop etc and the connection light turns on. I thought this would be a cool tool for troubleshooting copier network connections also. Currently this is how I do it. No connect light on copier nic, unplug from network and connect copier and laptop with a crossover or patch cable. Got light, prove to customer network issue, bye-bye.
    I see you can order on Eb@y, etc or make your own by hooking pins 1-3 and 2-6 on RJ-45 blank connector. I've tried to make my own, no soup for me. Didn't work on copier or laptop. I have also tried doing the gigabit one connecting the rest of pins. Same did not work.
    Does anyone use these? Do they actually work? Should I buy rather than make my own? I saw one other thread on this subject in the forum. And the writer says it works fine by making your own.
    I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
    Especially when it comes to sex
  • qbert69
    • Mar 2013
    • 1152
    Re: RJ-45 loopback tool
    Do you know the exact pinouts??? Does pinouts.ru have a diagram???[emoji848]
    Sent from my SM-N950U1 using Tapatalk
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
    • JLSam
      • Jun 2015
      • 605
      I... Have an easier method.
      Using a crossover cable i tether my copier and laptop. Put them in the same ip range, and set up printing and smb scanning. Thus proving network ability.
      Sent from my ONEPLUS A5000 using Tapatalk
      • Kimi
        • Feb 2018
        • 105
        Connecting your laptop to the copier should be enough to prove the fault is with the network. Leave the network troubleshooting to the customers IT and move onto the next job.
        • tjvincent
          • 280
          And then charge them something for wasting your time.
          • Bix
            • Apr 2018
            • 1421
            I connect the printer normally with any ethernet cable to my laptop.
            If I need internet access, on Windows I create a bridge between the wireless card and the network card. Then I start tethering on my smartphone.
            • JLSam
              • Jun 2015
              • 605
              Naturally. Slap on travel fee for good measure. [emoji1787]
              • tonerhead
                • Sep 2009
                • 582
                Here is link to one online comes to about $10 after shipping
                Gigabit RJ45 Loopback Tester | Computer Cable Store
                Thing is I rarely take laptop in on service call unless I need it. These items, you just plug into jack and copier link light lights. Don't need to lug in laptop and cable. Links for building your own are all over internet, so just google them if interested. It is basically tie pins 1 to 3 and 2 to 6 on cat 5 cable together, so all you really need is a cat5 that you can cut the end off and twist the wires.
                I would think this would be a benefit to me, not lugging a laptop in each time. Maybe I'm lazy, but I like the quick results type of things. I'm sure most of us carry the AC outlet checker and I also still carry the phone line checker from fax days (ran into a number of reversed ring /tip from homemade phone jack installs). Nice to carry one of these and have instant results on good nic or not.
                  • 37652
                  If you frequently are the customer's IT or have to install networking into a new building, it might pay to invest in a network testing equipment. I used to use a Test-Um LanScaper.
                  NDX8DXXX | LanScaper Network Tester Kit (8 Remotes)
