Sharp MX-5070N machine won't change Statatic IP
  • Copycat
    • Feb 2019
    • 16
    Hi, I have been working on a Sharp MX-5070N, I have been trying to disable the DHCP to manually enter a new static IP without any luck. After I submit and reboot the machine it goes back to DHCP mode.
    I tried replacing the SD card, Boot up the IC, and the Hard Drive and the device is still unable to respond to a change of IP address. It does not retain it. Other than that the copier works well.
    Any help would be appreciated,
    Thank you,
    AM
  • tsbservice
    Field tech
    • 8020
    Re: Sharp MX-5070N machine won't change Statatic IP
    Check for setting IP static not dynamic.
    • Chr15tophe
      • Dec 2011
      • 42
      Yes we have had that after being advised to do an eeprom clone and import. Wound up changing the main board, msata pwb and eeproms. but we also had other errors with machine so all three were needed in our case. Think you have a main pwb issue
      • repn1999
        • May 2010
        • 310
        ive seen strange issues like this when people clone all data from other families of machines. I have seen this once and had to wipe the hard drive replace the msata and program roms. I have also seen weird stuff where airprint shows a serial number not on the machine anywhere, and sometimes shows the serial of the machine it was cloned from. when we clone data now we just do the address book only. not worth doing anything else. too many issues that are difficult to solve and often costly.
