DI 650
  • poz31
    • Aug 2006
    • 86
    DI 650
    I have a DI 650
    The machine is installed with a print a internal print controller
    The costumer has a domain with Network solutions
    But no email is been received.
    Any dip swicht I need to set up???
    The email assigned to this machine has a user name and password
  • TheOwl
    • Nov 2008
    • 1732
    If I am right, then you have a Pi6500e which is the internal Fiery print controller.
    If this is the case, have a look at the Job Log in the Fiery. The machine reports that it is successful because it successfully handed the scan to the Fiery to handle. The Fiery may have not been able to transmit the email though.
    Also make sure that your mail server allows SMTP Relaying and if you are running a White List, add the Fiery IP Address to the list.
    Hope this helps.
    • Sean486
      ApSpec
      • Dec 2008
      • 39
      That model did not do SMTP Authhentication. If they are using that you may need to do scanning a different way. That would be either scanning to the Fiery's HDD using a Mailbox or scan to FTP and running an FTP service on the customers computer or server.
