KM C8000 unable to connect to Creo IC-307
  • PrintFacility
    • Nov 2013
    • 14
    We recently purchased a used C8000 with the Creo IC-307. The Creo does not see the machine connected to it. Dialog box with message "Can not access hardware components" (See attached screenshot).
    Could this be a Windows XP OS problem and not a Creo software or hardware issue? The Creo has the UK-103 dongle attached.
    To eliminate the machine interface or cable issue, I connected a Fiery IC-306 (from a C7000) which connected fine but will not print any files except for the configuration files from fiery Rip. I am assuming it needs the UK-102 dongle. Is there a work around.
    Kindly advice.
  • amarok
    • Feb 2016
    • 6
    Re: KM C8000 unable to connect to Creo IC-307
    We have same problem....
