Print ques won't show up in Devices and Printers
  • Master Sparkee
    • May 2010
    • 31
    Have had a problem for the past week that after installing printers on PC's. Same issue from multiple Windows versions. The printers won't show up in Devices and Printers folder until we reboot the PC's. Brand of MFP doesn't matter. Adding from server or via ip address doesn't make a difference. Printer drivers are listed in Print Server Properties and printers are listed in Device Manager. Hate the idea of rebooting client PC's just to install printers. Restarting print spooler or waiting it out have been tried. Anyone have a work around or suggestion?
    Sorry, no. Techs don't carry toner.
    • 29399
    Re: Print ques won't show up in Devices and Printers
    Best fix is to reboot, have seen this also sometimes it you wait a few minutes it's appears other times it reboot time.
    Got to love windows 10 til the next update
    • Master Sparkee
      • May 2010
      • 31
      [QUOTE=bsm2;809157]Best fix is to reboot, have seen this also sometimes it you wait a few minutes it's appears other times it reboot time.
      Got to love windows 10 til the next update[/QUOTE
      That's why I'm here. We install at pretty large locations and reboots are going to be a massive headache that I'm hoping we can avoid
      • dave w
        • Jun 2015
        • 230
        Yes
        I have seen this a few times, Also unable to look at the properties until I reboot.
        • BaconSteve
          • Apr 2019
          • 140
          • tsbservice
            Field tech
            • 7911
            Master Sparkee, looks like you covered most of basics and I'm afraid bsm is right on living with it waiting for a next M$ update to correct what they screw up.
            I will follow this topic.
              • 36851
              If the printers are installed on and shared from a file/print server, immediate rebooting may not be an option. Scheduling down time will be necessary. If a customer has an IT or IT service, it is best to have them install the drivers. Protects your ass in case of a problem.
              • allstar59
                • Oct 2012
                • 61
                I've had something similar happen three times today installing a kyocera MFP. I install the print driver and the copier shows up under the unspecified devices section and shows a message that the device is installing. It seems to take forever to install but eventually finishes. While it is doing this I can't access any properties or remove it. I had to just leave it and come back later to see if it finished.
                • keithxxiii
                  Just a tech
                  • Nov 2014
                  • 468
                  Had this problem on a windows 2016 server. I have restarted a couple of times but still the same display. Might be another windows update that will fix this.
                  Aye! Cut the crap
                  • Blizzoo
                    • Aug 2013
                    • 594
                    I noticed that in Print Management it does show the print queue if in Devices and Printers doesn't show up. As stated up, windows restart solves it
