Office365 stops accepting email from copier
  • mincopier
    • Dec 2015
    • 289
    Went to a machine today that another tech was having problems with. When I got there email worked. Upgraded the firmware anyway, it needed it very bad. It still worked after the upgrade. I sent several emails back to back and even to everyone registered in the machine at one time. I get a call about two hours later that it quit working again. I have not tried setting the SMTP to the IP of the Office365 server yet. The fact that it worked while I was there tells me there is nothing wrong with the machine itself.
    The machine is a Savin C2003 with the latest firmware available
    Smtp: smtp.office365.com
    Port:587
    SSL is "On"
    Administrator, login name and user name are all the same email
    We are going to try our own login on Monday to see if it works longer and possibly changing the SMTP to the IP.
    Any other ideas that I should check.
  • tsbservice
    Field tech
    • 8019
    Re: Office365 stops accepting email from copier
    I don't know Savin but ot KonMin settings are:
    Setting IMAP (incoming)
    Server Name outlook.office365.com
    Port Number 993
    Encryption Method SSL
    SMTP (outgoing)
    Server Name smtp.office365.com
    Port Number 587
    Encryption Method TLS
    You may also look at the following page for other specifics.
    How to set up a multifunction device or application to send email using Office 365 | Microsoft Docs
      • 8206
      Port Number 993
      SMTP (outgoing)
      Port Number 587
      Very useful link.
      Thanks,
      • copiertec
        • Jan 2016
        • 2209
        Port:587
        SSL is "On"
        Is the MFP showing the email has been sent or has it errored out? Have they checked their spam folder? I have had a few instances where the client complained about not getting their emails, however, the email was marked as spam by Office 365 and their IT provider had to go further than just white-listing the email coming from the device, in office 365, they had to make further exceptions,since the IT dept has made those changes all has been good.
          • 37513
          Port Number 993
          SMTP (outgoing)
          Port Number 587
          Very useful link.
          Thanks,
          Yes it is. I have posted to a number of thread about Office 365. Most idiots seem to ignore it.
          • mincopier
            • Dec 2015
            • 289
            Will check that thread.
            When I was testing after the firmware upgrade it showed up in everyones "Inbox", that should not have changed.
            As far as leaving the machine Or not I'm not sure at this time. I will look into that when I get back there.
            • D_L_P
              Self Employed
              • Oct 2009
              • 1196
              Port:587
              SSL is "On"
              I've had this issue before. The sent box has a finite amount of data and needs cleaned out from time to time depending on how much is being sent.
              https://www.copytechnet.com/forums/c...tml#post711664
              • tsbservice
                Field tech
                • 8019
                slimslob, I was searching for this thread problem solutions using Google. That link was one of the first few ones I figure it out as potentially helpful. My bad if did something wrong.
                • mincopier
                  • Dec 2015
                  • 289
                  I still have not seen this not fail at this customer. We had another tech go by and it failed at the machine. We loaded info for a different O365 account and it worked for about 5 minutes. So it is not an O365 issue. We even tried by IP address and it would still fail at the copier after a little time. We are not thinking local network issue.
                  • JVergin
                    Service Tech / IT Rep
                    • 216
                    Had a similar problem happen once. Somehow it didn't affect printing but one of the TVs in the building took the IP address of the copier causing intermittent scan to email errors (On a Kyocera product).
                    Try unplugging the network cable from the copier and pinging it's IP address. If it still pings successfully then see if the network admin can find out what device is using that IP, kick it off, and reserve that IP for the copier.
                    • BHM
                      • Feb 2011
                      • 126
                      Repeating earlier suggestions
                      smtp.office365.com
                      TLS port 587
                      Add 8.8.8.8 as one of the dns servers.
                      Never fails for me.
                      I have seen an incorrect email address programmed as a send to address cause a send failure.
                        • 37513
                        smtp.office365.com
                        TLS port 587
                        Never fails for me.
                        There is a specific problem recipient address is with a number of non ISP email providers. When the sender domain and the authentication domain do not match, the email is rejected and an error report is sent to the sender.
                        • clint@clintsimonsen.com
                          • 125
                          As an IT consultant, who still has a foot in the copier business.
                          It is getting to be best practice to disable SMTP and legacy authentication for Office 365. As part of increasing the secure score in office 365.
                          As part of our business processes we have been moving our customers copiers over to SMTP2go with a private domain. We've found that this is a great way to keep our customers working and secure/compliant.
                          Sent from my ONEPLUS A6000 using Tapatalk
