Collecting Device Counters from USB connected Printers
  • keithxxiii
    Just a tech
    • Nov 2014
    • 468
    Hi everyone,
    We have a client with more than 400 devices on their fleet. We use @remote to send out counters for billing and supplies replenishment. Unfortunately for us, we also have more than 100 devices connected on USB cable without network connectivity. Getting the counters and supply status has been a challenge for us.
    I would like to know what software are you using in collecting the meter readings?
    TIA
    Aye! Cut the crap
  • BaconSteve
    • Apr 2019
    • 140
    Re: Collecting Device Counters from USB connected Printers
    FM Audit: same usb meter and supply level collection limitation.
    • diedux
      • Jan 2017
      • 124
      Hi. In general USB connected printers are not tracked, that's my attitude toward this matter. All software, agents, print monitors, etc. are just workaround to this problem. Don't want to go deep into it, just saying from personal experience.
      Yet, you can get some insight into your fleet using one of these:
      Infinite Device Management
      PrintFleet
      Print Fleet Management software - PrintAlerts from ITS
      Good luck.
        • 30167
        Print tracker will work but only on mono machines not color
        • Bix
          • Apr 2018
          • 1421
          It happened to me once that I had a multifunction printer without internet. But I was also lucky and now I'll explain why:
          the computer is connected via the wireless network. If the ethernet port is free, in the Windows settings you can create a point between the ethernet port and the wireless card.
          The printer connects it to the Ethernet port while the PC continues to work with its wireless module. In other cases we have bought a wireless repeater with an Ethernet port. It costs less than 30$
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            PrintFleet
            Good luck.
            If there are only a small handful of USB devices, it’s not normally much of a concern.
            If there are a number of them, it is absolutely a huge issue.
            Since most printers that are connected USB are typically very small, their cost per print are waaay higher than larger machines.
            Frequently, the supplies are paid for by the company by the user simply expensing them. These expenses normally aren’t tracked very well, if at all. The company has no idea of what they are actually spending.
            I’ve done a ton of print studies using various methods to get meters (including going printer to printer) over the years. Then work with the customer to find out what they have paid for supplies, which is by far the harder part.
            All that work is almost always worth it. Let’s just say the results are quite eye-opening.
            • Kimi
              • Feb 2018
              • 105
              I posted about Netaphor Site Audit in this thread, it supports usb connections apparently
              print volume reporting solution for USB connected Ricoh printers
              • keithxxiii
                Just a tech
                • Nov 2014
                • 468
                let me try this as I totally gave up on Web JetAdmin and FMAudit
                Aye! Cut the crap
                • keithxxiii
                  Just a tech
                  • Nov 2014
                  • 468
                  can't get pass through the license page, and none on the website shows if we can use a trial or POC
                  Aye! Cut the crap
