Google mesh network and non wireless MFP
  • Hansen88
    • 1068
    Hello, customer has a Sharp MX-M453n which is a little older,no wireless. Customer is getting a google mesh network,which I have never heard of. From reading up about it,it looks like this copier wont work with google mesh. I am wondering if anybody that knows about google mesh if the copier can be hard wired to one of the mesh routers or if there is some other kind of workaround to be able to use this machine. Thanks for any help on this issue.
  • Kimi
    • Feb 2018
    • 105
    Re: Google mesh network and non wireless MFP
    Adding LAN ports to Wifi point - Google Wifi Help
    This suggests the primary point will have a LAN port.
    Otherwise buy a cheap wifi antenna and connect it to network then connect it to the copier by network cable.
    • qbert69
      • Mar 2013
      • 1152
      Vonets wireless bridge. They can be found on Ebay![emoji6][emoji1303]
      Sent from my SM-N950U1 using Tapatalk
      REACH FOR THE STARS!!!
      Konica Minolta Planetariums!
        • 37503
        A WIFI range extender with a wired port works nicely. Netgear N300 WiFi Range Extender Model EX2700 works nicely and be found at numerous places for less than $50.
        In fact a mesh network is merely and number of dual band routers/extenders working together to eliminate dead spots. Each router/extender normally includes at least one available port so if the Sharp is near one of those you might be able to connect to it.
        EX2700 | WiFi Range Extenders | Networking | Home | NETGEAR
        • Hansen88
          • 1068
          Thanks guys,looks to not be a problem then with their existing machine. Customer will be happy about that.
          • MattL
            • Apr 2012
            • 97
            All the Google Mesh will be are some access points, at least one of them will still connect back to a switch/router so I'd just leave the copier plugged into that.
