Mpc 6501 E-7200 30x60 Paper
  • anpetros
    • May 2011
    • 43
    Hello .
    I have this problem with an E-7200.Trying to print on 30x60 long paper size and i get the message:Invalid print size.Press reset to continue.No other option.Just to press reset.I have switched sp mode to long paper size,on the fiery printing screen 30x60mm paper is available but cannot be printed.
    When i try to copy from the platen glass for example an a3 to 30x60mm everything it is printed ok from the b/p tray .What's the solution to this?
    • 36948
    Re: Mpc 6501 E-7200 30x60 Paper
    Replace the toner belching monster with something newer. Preferably a true Production Machine.
    • anpetros
      • May 2011
      • 43
      I didn't ask if the machine is a monster.I know it.Is this the way you've made 5000+ posts?You probably don't know the answer....
