Remote Install
    • 30186
    Remote Install
    Did my first full remote install today 4 pc's
    Setup print driver and scan to folder. Not to bad took a little more time but it's done.
    Lexmark MX812de
  • diedux
    • Jan 2017
    • 124
    Re: Remote Install
    Every other time will take less and less time. Well, at least that's what i wish for you.
    Cheers!
    • BHM
      • Feb 2011
      • 126
      Re: Remote Install
      I am assuming to are remoting into the customer's computer. What did you use to remote in? I have been using TeamViewer but their user licenses are expensive in my opinion. I can only think of maybe 2 or 3 times that I could not get it to work and it was more than likely the user on the other end.
        • 30186
        Re: Remote Install
        Check your PM
        • mincopier
          • Dec 2015
          • 289
          Re: Remote Install
          We use GotoAssist ourselves. Connectwise is one I'm looking at for next year. It is about $250 cheaper. One of the IT companies we work with uses it.
          We have not done a full install through the remote. A lot of back and forth for the customer but in these times it is not a bad idea. A lot of the speed to get it done is highly dependent on the internet speeds also.
          • allstar59
            • Oct 2012
            • 64
            Re: Remote Install
            We use Splashtop SOS
            Dirt cheap and it works great with Windows ans Mac
              • 30186
              Re: Remote Install
              I use zoho remote has a free and also low cost pay option, but free does what i need works on all OS
              • diedux
                • Jan 2017
                • 124
                Re: Remote Install
                I use free version AnyDesk. Simple, no registration, no install, no ban due to excessive use.
                • tsbservice
                  Field tech
                  • 8007
                  Re: Remote Install
                  We also use AnyDesk, simple an troublefree.
                    • 8193
                    Re: Remote Install
                    TeamViewer is by far the best known, is easy for customers to install and most likely to be accepted by IT Managers concerned about security.
                    TeamViewer secretly tracks the usage from your computer. When you hit 800 minutes, you are no longer eligible for free usage.
                    • srvctec
                      Former KM Senior Tech
                      • Oct 2009
                      • 827
                      Re: Remote Install
                      That's good to know since I wasn't aware of that limitation, although I can't find any confirmation of this limitation in a brief online search. Is this info publicly available or widely known?
                      I only use TeamViewer to help my mom whenever she has PC issues and have been using it for many years. My guess is I'll never get up to 800 minutes since most of our sessions are just a few minutes for me to figure out/fix her issue.
                      Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                      • diedux
                        • Jan 2017
                        • 124
                        Re: Remote Install
                        This is a well-known limitation for those who use Teamviewer free version. Just Google "Teamviewer 5 minute limit" if you're interested.
                        • NeoMatrix
                          Senior Tech.
                          • 3513
                          Re: Remote Install
                          Remote install we use TeamViewer.
                          We can remote into Point Of Sales (POS) cash register systems an program the system directly.
                          The POS is linux OS. We normaly do this via Windows Operating system an TeamViewer.
                          • peter42
                            • Jan 2012
                            • 110
                            Re: Remote Install
                            We use a licensed Teamview and our customers can download a personalized client (in real its a standalone server) with our companylogo on it from our website.
                            Sometimes the customer has a newer Vers. and we cant log in.
                            Then the download helps a lot.
                            The customer need no installation, he can start the software directly and after use,
                            there is no service running until he start it again and a new password is then automaticaly generated.
                            Most IT responsible like it, there is no hidden access for me.
                            • srvctec
                              • Oct 2009
                              • 827
                              Re: Remote Install
                              I found plenty on the 5 minute limit which has never caused an issue with me helping Mom and I think I've had lots of sessions over 5 minutes on the free. What I didn't find any info at all on is the 800 minute limit I quoted, but thanks for the info.
