SMB scanning to Windows Server 2019
  • BHM
    • Feb 2011
    • 126
    We have a customer that upgraded to Win Server 2019. Our Bizhub 458 (non e) cant scan to that machine. We get a server connection error.
    We can scan to a Win10 pc using the same exact credentials.
    We can browse to the scan folders on the sever using the same credentials the copier is using.
    I believe the f/w version was G00-W5 and Function version was 4.2
    It is on a domain.
    I have not dealt with a 2019 server and am unaware of any special settings. I am opening an email hotline ticket with KMBS thought I am not sure of their response time currently. Any thoughts?
    • 30229
    Re: SMB scanning to Windows Server 2019
    Most likely a security issue that is out of date.
    • tsbservice
      Field tech
      • 8018
      Just a thought.
      As W5 FW is from 2018 I would step up update to latest recent FW version X4. Not considering special FWs.
      Let us know.
        • 37502
        It is on a domain.
        Anytime you are on a Server Domain, you have to properly set the domain name in your network interface settings. One typo and you will not be a part of the domain. In addition, the first DNS must be the domain DNS.
        If the Bizhub has not been power cycled since the Server 2019 was installed, doing so now might pickup the correct information from the DHCP.
          • 8197
          For printing make sure that the Windows Type 4 driver is not being used. You must use the latest driver from the manufacturer.
          • BHM
            • Feb 2011
            • 126
            Had a tech go out this morning and install version X4 and still no luck. Have not tried power cycling the meter but I did copy and paste the domain name into the copier.
            One other curious thing is the smb scan error displayed in the job list shows 16712685 which does not appear on the SMB error list. Never saw a code with that many digits. Tech is going there later and will try rebooting. If that does not work, they are ok with scanning to computers so we might wait until we get another Server2019 issue to confirm if is is some weird random issue or something with 2019.
            • tsbservice
              Field tech
              • 8018
              Error Code List
              Error 16712685:
              The user name is not specified.
              Could not log in using the specified user name and password.
              The user failed to log in because an error has occurred in the SMB protocol that has no write permissions to the folder.
                • 37502
                Error Code List
                Error 16712685:
                Sounds like the user either was not added to Active Directory users for the Server 2019 or was not spelled correctly when added.
                • BHM
                  • Feb 2011
                  • 126
                  Error Code List
                  Error 16712685:
                  Oh man, thanks for that updated list of error codes!!! It has a lot more codes than my current list. Login errors in these situations are my nightmare. Sometimes you have to rely on the IT person to have correctly done their part and of course they never ever make mistakes. lol
                  Thanks so much!
                    • 30229
                    Does it fail using the admin sign in?
                      • 37502
                      Maybe you give the admin credentials to vendors, but most quality IT people don't.
                        • 30229
                        Duh your Not a IT tech. For testing ONLY!
                        If it works it's a security permission issue.
                        Stick to main body
                        • BHM
                          • Feb 2011
                          • 126
                          Mentioned to him that it was login issue and he was going to verify the credentials. Never heard back from him. I went there today and looks like he set up scanning to individual computers with different credentials than what he was using with the server.
                          • Bix
                            • Apr 2018
                            • 1421
                            Originally posted by captainrva
                            I have this exact same issue and it fails for the administrator account as well. I switched the MFP to SMB v2/v3 and I get a login error. Did anyone ever figure this out?
                            Hi, you are better off creating a new thread. What computer does it not work on? Which printer model? Provide more details
                              • 37502
                              I'm using a Bizhub c300i with the latest FW and I am trying to scan to Windows Server 2019. I can scan to windows 10 using smb v2 without any issues but I can't scan to Server 2019. I am getting a login error.
                              What part of creating a new thread are you incapable of understanding?
