SMB SCANNING NOT WORKING
  • niyaskarimba
    • Sep 2014
    • 110
    Dear All,
    SMB Scanning not working for few pcs (CANON IRADVC 5051/5250)form different customer locations tried the follow setting
    1.SMB1 is enabled(Programs & features)
    2.checked all the settings in network & sharing center(Password protected sharing is off)
    3.Checked & varrified inbound rules in the firewall setting
    4.Tried by turn off firewalls in the antivirus also
    Kindly suggest any other solution please.
    Thanks in advance.
    • 37521
    Re: SMB SCANNING NOT WORKING
    If the Image Runners have not been updated to be able to use SMBv2/v3 you need to do so. Microsoft considers SMBv1 to be a potential security issue and disables it. You can enable it if you wish but the next Windows Security Update will disable it again.
    • tsbservice
      Field tech
      • 8020
      Newest M$ updates cause havoc on older MFPs. Especially when it comes to SMB v1. You shouldn't use it. Update machine firmware or use scan to FTP.
      • giogi
        Engineer senior
        • Jan 2016
        • 181
        you need to install special firmware
        "Knowledge is a source, but unfortunately ignorance is a sea."
        • niyaskarimba
          • Sep 2014
          • 110
          [ATTACH=CONFIG]46052[/ATTACH]
          Ok.Thanks
          We will try to update the firmware.
