100 + print drivers to create and configure
  • Chr15tophe
    • Dec 2011
    • 42
    Hi all,
    We have a customer who wants to create over 100 print drivers with different configs on each, does anyone know a quick way of duplicating a print driver on a server? or if they'll actually be any performance issues to the end user when they goto select a driver from the drop down list ?
    thanks
    • 16399
    Re: 100 + print drivers to create and configure
    I'm not following what you're trying to accomplish by installing 100 print drivers with different configurations? What is it that you're trying to accomplish exactly?
      • 30267
      You create different printers with default setting ie output from tray 4 etc...
      Driver is already installed you just add printer
      You can also setup custom profile within the print driver and name them within the driver
        • 16399
        That's what I would do.
        • qbert69
          • Mar 2013
          • 1152
          Print driver presets within the print driver. Some manufacturers allow you to save the presets to a folder. Once all presets are saved to the folder, the folder of presets can be copied to a server and pulled down to each pc. Or perhaps the presets can be created on the server and pushed down to individual pc's???[emoji848] Either way, it sounds like you're dealing with a bit of instantiation overload!!![emoji15][emoji57]
          Sent from my SM-N950U1 using Tapatalk
          REACH FOR THE STARS!!!
          Konica Minolta Planetariums!
            Originally posted by Chr15tophe
            Hi all,
            thanks
            Are they trying to give each user their own profiles?
            Different paper trays/paper for certain jobs?
            Are they storing them on the server?
            Are you charging for each profile ( i set up basic drivers on up to 5 PC's for the setup/install charge)
            • D_L_P
              Self Employed
              • Oct 2009
              • 1196
              Hi all,
              thanks
              They can make a simple script in C# for duplicating an existing printer.
              The 'InsallPrintQueue' class along with modifying the relevant strings would copy an existing queue.
              • Chr15tophe
                • Dec 2011
                • 42
                Cheers all, we cut the drivers down to 11 after a conversation
                  • 37517
                  Ricoh has a utility for their pcl6 drivers called Print Driver Packager NX that allows IT to build driver packages for deployment through Group Policy.
