Windows Error Causing Computer To Reboot During Print Jobs To Kyocera Copiers
+ More Options
Posts
  • tecchie
    • 118
    Hi All
    Not sure if Im in the right forum for this buts heres my problem.
    This is my third call over the last week with some of my customers getting a windows error causing a reboot during print jobs.
    The error is Stop Code:APC_INDEX MISMATCH What Failed win32kfull.sys
    Im aware of the bad Microsoft Update that we corrected with similiar blue screen problems most of which we corrected with updating computers with new microsoft corrected update or rolling back computers that didnt have the update available yet.
    Heres my problem. If i go to the computer and run check for updates theres nothing available and in the update history the bad update is not in there or the fix does not show as updated. Is there a way to manually download the patch and update. To my knowledge the bad update was KB5001649 which microsoft pulled back and modified. Should i be looking for something else or do i have to wait for next Microsoft update roll out which im being told is not until 4/15/21
    If this was just one instance i would dig deeper but three of the same problems with exact errors all of a sudden leads me back to the Microsoft problem. All of the multi-funtion machines firmware is current as well as the print drivers. Weve tried kx as well as pcl drivers with same end result.
    • 29823
    Re: Windows Error Causing Computer To Reboot During Print Jobs To Kyocera Copiers
    New Windows 10 emergency updates fix remaining printing issues
      From the article that you posted:
      When attempting to install the update, some users are reporting receiving an error stating "We couldn't install this update , but you can try again (0x80070541)."
      If you run into a similar error, you can manually install the update by downloading it from the Microsoft Update Catalog.
      I told you that it doesn't always work from Windows Updater. Been there, done that.
        • 29823
        Thanks buddy unfortunately for U I can read
        Back to school
          Back to school
          If you say so. You disagreed (to put it mildly) when I told you this a week ago. Moving on....
            • 29823
            Good advice Move on
            keep learning little buddy
            Glad I could help u out again
              Good advice Move on
              You need to stop your shit. You aren't educating anybody but we have schooled you on everything from spelling..to proper usage.. to the lies you tell about Trump and what a lousy job your 'hero' SnifferJoe et al are doing to this Proud country.
              Cut the shit, mommies ready to change you diapers.
                • 29823
                Sorry Phil I don't date men but maybe you can ask Billy
                  Neither do I but copier addict says he would and you being his buddy I figured you were his bitch.
                  As far as Billy goes he is a straight shooter so I figured he doesn't either.. we leave the ' Hersey highway rangers ' up to you queer mother fuckers!
                    • 37252
                    Originally posted by tecchie
                    Hi All
                    There are a number of threads covering this problem both in the Connectivity forum and individual manufacturer forums. Here are a couple on Kyocera that you might want to read.
                    https://www.copytechnet.com/forums/c...9=#post1706717
                    https://www.copytechnet.com/forums/k...6=#post1706733
                      Hi All
                      You need to go to Microsoft Update Catalog. See link: Microsoft Update Catalog
                      From there you need to find the patch that works with your version of windows. See list below. Let me know if you have any questions.
                      Win 10 v.20H2 - KB5001649
                      Win 10 v.2004 KB5001649
                      Win 10 v. 1909 - KB5001648
                      Win 10 v. 1809 - KB5001638
                      Win 10 v. 1803 - KB5001634
                      Win 10 v. 1507 - KB5001631
                        • 29823
                        No worries the link I provided in the #2 post already gave him the correct information
                        including the link to MS catolog
