Can't get Taskalfa 2553ci to connect with Emailsrvr.com
  • kyotechnz
    • Mar 2019
    • 152
    I am getting a 1102 error (Login Username or Login Password) when trying to get a Taskalfa 2553ci to connect the Emailsrvr.com mail server.
    All the settings on the copier are correct. The Username and Password are correct.
    I can login through the Website with the login and password.
    Does anyone know if there is setting like "Less Secure Apps" in Gmail that needs to be set with Emailsrvr.com? Or some other security setting?
  • Santander
    • May 2009
    • 768
    Re: Can't get Taskalfa 2553ci to connect with Emailsrvr.com
    Did you set the senders info? When you setup the SMTP server info and tested did it work? Not entering the senders info such as info@xxx.com will cause a problem. The username and password can be correct but if you did not enter sender info it will fail. On some email systems if the subject line is blank it will also fail. Hope this gets you pointed in the right direction,
      • 30554
      Does it required ssl or tls?
        • 30554
        Emailsrvr.com (Rackspace Email Hosting) SMTP Server secure.emailsrvr.com
        SMTP port 465
        SMTP security SSL / TLS
        SMTP username Your full email address
        SMTP password Your Emailsrvr.com password
          • 30554
          SMTP port 465
          Turning on ssl/tls requires a reboot for the setting to take effect.
