Canon C5030 UFRII driver on Mac keeps saying printer in use
  • mrfixit
    Senior Technician
    • Sep 2007
    • 83
    So I have run into this problem twice in the last week. I install the Canon UFRII driver on a Mac and every thing seems to be fine but when I try to print I get a printer in use message. The first time it was a C5200 series and I was able to set up through airprint but this tim it is a C5000 series that doesn't support airprint. Has anyone else experienced this issue? I'm a pc guy and not terribley familiar with the newances of Mac's. Thanks Ray
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Re: Canon C5030 UFRII driver on Mac keeps saying printer in use
    This should work for you:
    Download driver and extract
    Add printer: go to IP
    enter canon ip
    protocol:Line Print Daemon-LPD
    use: Select Software> Canon iR-ADV C5030/5035> ok> add
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
      • 30213
      Canon has a PS driver for Macs
      • Venom
        • Nov 2009
        • 765
        PS was an option for that model, check it is installed on device first
