windows 10 home s mode not scaning to konica bizhub224e
  • COPIERMAN
    • Jun 2009
    • 559
    I turn off s mode which allow me to setup the printer. i setup a new local user . Create my folder giving everyone and my local user full permissions and also in security tab verify they were there also with full permission. create address on copier and when i scan says server connection error. I have triple check my settings everything is correct. Any help is a appreciated
  • tsbservice
    Field tech
    • 8064
    Re: windows 10 home s mode not scaning to konica bizhub224e
    Check that windows is in private network, network discovery should be turned on also.
    Check bizhub FW version newest base are like G20-M1 if I remember correctly.
    • Brischaffer
      • Oct 2008
      • 68
      In Programs & Features - Turn Windows Features on or off - Make sure SMB is turned on. If not turn it on and reboot your CPU. That should fix the issue.
      • COPIERMAN
        • Jun 2009
        • 559
        i fix problem saw a post were they say on computer to use net-bios to TCP instead of DHCP in ipv4 properties under advance settings. thanks everyone for there help.
