Google Workplace / Gmail
  • mansart
    • 852
    OK here is what I know...
    • Sharp MX2640 configured to scan to email via SMTP2GO account.
    • Machine has been emailing successfully for approx 2 years
    • Client now reports they are not getting emails scanned to their email addresses
    1. Client uses Google Workplace for their email services.
    2. I can scan successfully to email to Yahoo.com, Live.com, gmail.com
    3. I can scan to Google workplace (our dealership uses Google SMTP via workplace just like the client)
    Emails sent to clients address leave machine successfully but never arrive in their inbox. Emails are not in SPAM.
    Using the Google email log search the emails are not found
    SMTP2GO server shows the messages arriving and being processed but never delivered.
    I can find no rules or filters in the clients Admin console that would filter out and/or block these emails.
    Any suggestions welcome.
    TIA
    • 8179
    Re: Google Workplace / Gmail
    Maybe Two Factor Authentication (2FA) is enabled in Google. If so, yo need to make the necessary changes in your SMTP client on your copier.
    • mansart
      • 852
        • 8179
        It is not about the send. It is about the receive. Easy to Check in Gmail under Security.
        • mansart
          • 852
          I can check but I'm unclear how 2FA would affect the receiving of email.
          • mansart
            • 852
            2FA is not on
              • 8179
              Google Workspace (formerly known as Google Apps and later G Suite).
              Sorry, I do not work on Sharp copiers. You should reach out to their tech support.
                • 37448
                Actually the changes need to be made in SMTP2GO since that is what communicates with Google Workspace.
                • spanky
                  • Sep 2012
                  • 468
                  If they are using G suite you have to activate the Less secure APS in their G suite settings.
                    • 37448
                    G suite has been replaced by Google Workspace.
                    • clint@clintsimonsen.com
                      • 124
                      Is the copier using the same @customerdomain as the receiving, have you added the cname for it in SMTP2go? You may like to use a different from address on the copier to test
                      Sent from my Nokia 8.3 5G using Tapatalk
                      • mansart
                        • 852
                        Unclear on the resolution, however clients IT came in and I was told they replaced the router??
                        Doesn't make sense to me to but, it's working and I'm out of there...
                        Thanks for replies
