MS TLS1.0 and 1.1 deprecation affecting Office 365
  • calebgk
    • Jan 2019
    • 21
    Does anyone know if Microsoft finally deprecated TLS 1.0 and TLS 1.1 on the weekend? They had this scheduled for October 2020, but it was delayed due to pandemic. I had 15 calls this morning for O365 SMTP not working on our Kyocera MFPs. Setup O365 with STARTTLS on port 587, same as they always have been, but they start getting x4803, which is an SSL error. I remove SSL3.0/TLS1.0 and TLS1.1 from both Serverside and Clientside settings of Network Security, and scan to email starts working again. I leave TLS 1.2 enabled, as well as SHA1 and SHA2 as they are needed for KFS. Has anyone else come across this situation starting only this week?
  • rthonpm
    • Aug 2007
    • 2860
    Re: MS TLS1.0 and 1.1 deprecation affecting Office 365
    Support for TLS 1.0, 1.1, and 3DES ciphers in Microsoft 365 ends 31 January, 2022.
    At this point there's not much reason to keep anything older than TLS 1.2 enabled on any device as it just opens the possibility of downgrade attacks.
    Sent from my BlackBerry using Tapatalk
    • copyman20
      • 207
      Some of our customer are getting intermittent 4803 errors. It was sort of hard to pin down what was going on because we test the settings with OK result. 20 minutes later 4803.
      We were going to have some devices with TLS1.0, 1.1, 1.2 all selected on both server and client side and some with with only TLS 1.2 turned on.
      • kilgan
        • Oct 2021
        • 3
        I am getting the same thing.
        Even with 1.2 just checked. (attached) I am still getting errors.
        Is there any resolution to this issue?
        My Version Info on our TASKalfa 4501i
        System : 2N9_2000.004.505
        Engine : 2N7_1000.004.002
        Panel : 2N4_7000.004.501
        Scanner : 2N4_1200.003.001
        FAX : 3N6_5100.B06.001
        • Brianneoe
          • May 2015
          • 322
          Kyocera help desk helped with this one and it worked..Go to network security, turn off SSL, TLS 1.0 and 1.1 . Leave TLS 1.2 enabled, as well as SHA1 and SHA2 as they are needed for KFS.
          • calebgk
            • Jan 2019
            • 21
            3DES encryption was deprecated along with TLS 1.0 and 1.1. Turn off 3DES under Effective Encryption. And make these changes under both Serverside and Clientside. That's been working for about 40 of my clients who have called in about this.
            • toddanderson
              • Dec 2005
              • 238
              Are you talking about any kyocera devices ? and turning off 3DES ?
              • calebgk
                • Jan 2019
                • 21
                I just work with Kyocera, so I can't comment on other equipment. But we have been turning off 3DES along with TLS 1.0 and 1.1, as they were listed together in MS's end-of-life announcement from last year. Not sure if it has any bearing on O365 errors listed above.
                Note: Network fax driver for Kyocera needs SSL to communicate with MFP, so only turn off SSL3.0, TLS1.0/1.1/3DES on clientside settings, and leave SSL3.0/TLS1.0 enabled on serverside settings, otherwise network fax driver will stop working.
                • bronco31
                  • Aug 2009
                  • 174
                  also here..various office Kyocera unable scan to O365
                  im hazy on server vs client side..whats the difference.. the Kyo Command Center Guide under Network Security Settings (to turn on/off SSL3 /TLS/ encryption/ has etc) .. theres setting for both server and client side.. client side being the PC side? .. im cornfused
                  but OK, thx Brian...will try this:
                  "Kyocera help desk helped with this one and it worked..Go to network security, turn off SSL, TLS 1.0 and 1.1 . Leave TLS 1.2 enabled, as well as SHA1 and SHA2
                  "3DES encryption was deprecated along with TLS 1.0 and 1.1. Turn off 3DES under Effective Encryption. And make these changes under both Serverside and Clientside. That's been working for about 40 of my clients who have called in about this."
                  • jcassidy
                    • Aug 2021
                    • 7
                    Haven't gotten a look yet, but some Sharp have come up late this afternoon. Had Kyoceras last Friday.
                    • calebgk
                      • Jan 2019
                      • 21
                      You could simplistically look at it as Serverside as Incoming (like network fax coming into MFP from a PC) and Clientside as Outgoing (like MFP sending email out thru SMTP). Not a true explanation, but it's the basic idea.
                      • eescamilla
                        • Aug 2015
                        • 58
                        Would an older series models like a 3500i have all those security options? I think those have the older style web interfaces.
                        • Santander
                          • May 2009
                          • 768
                          No they do not. Microsoft had some push back on this and have enabled a new endpoint on the site that allows legacy devices like the 3500i. This is info I got from the MS O365 website:
                          To take advantage of this new endpoint, admins will have to:
                          1. Set the AllowLegacyTLSClients parameter on the Set-TransportConfig cmdlet to True.
                          2. Legacy clients and devices will need to be configured to submit using the new endpoint smtp-legacy.office365.com
                          Hope this helps, I will be trying it tomorrow on a customer's 4500i
                          • calebgk
                            • Jan 2019
                            • 21
                            Please report back on this. I haven't tried the legacy settings yet. This is only supposed to work until Feb, so I encourage my clients to find alternative SMTP now.
                              • 37641
                              It is simply a relay server. It receives the incoming emails, adds the necessary protocols and relays the emails on the the Office 365 server cloud. It saves major corporate IT companies from having to setup their own relay services.
