Re: MS TLS1.0 and 1.1 deprecation affecting Office 365
How to set up a multifunction device or application to send email using Microsoft 365 or Office 365 | Microsoft Docs
Pretty good recent MS doc covering the different options/features/restrictions with links to the relevant 'how-to'.
My understanding is that not using the "Legacy" relay server will end in February. That is how long Microsoft is giving everyone to convert to the Legacy server.Leave a comment:
Using the legacy settings works just fine, simple fix. I saw nothing on the MS website that said that the legacy endpoint was only good until February.Leave a comment:
No they do not. Microsoft had some push back on this and have enabled a new endpoint on the site that allows legacy devices like the 3500i. This is info I got from the MS O365 website:
To take advantage of this new endpoint, admins will have to:
- Set the AllowLegacyTLSClients parameter on the Set-TransportConfig cmdlet to True.
- Legacy clients and devices will need to be configured to submit using the new endpoint smtp-legacy.office365.com
Hope this helps, I will be trying it tomorrow on a customer's 4500iLeave a comment:
I just work with Kyocera, so I can't comment on other equipment. But we have been turning off 3DES along with TLS 1.0 and 1.1, as they were listed together in MS's end-of-life announcement from last year. Not sure if it has any bearing on O365 errors listed above.
Note: Network fax driver for Kyocera needs SSL to communicate with MFP, so only turn off SSL3.0, TLS1.0/1.1/3DES on clientside settings, and leave SSL3.0/TLS1.0 enabled on serverside settings, otherwise network fax driver will stop working.Leave a comment:
also here..various office Kyocera unable scan to O365
im hazy on server vs client side..whats the difference.. the Kyo Command Center Guide under Network Security Settings (to turn on/off SSL3 /TLS/ encryption/ has etc) .. theres setting for both server and client side.. client side being the PC side? .. im cornfusedLeave a comment:
Haven't gotten a look yet, but some Sharp have come up late this afternoon. Had Kyoceras last Friday.Leave a comment:
but OK, thx Brian...will try this:
"Kyocera help desk helped with this one and it worked..Go to network security, turn off SSL, TLS 1.0 and 1.1 . Leave TLS 1.2 enabled, as well as SHA1 and SHA2
"3DES encryption was deprecated along with TLS 1.0 and 1.1. Turn off 3DES under Effective Encryption. And make these changes under both Serverside and Clientside. That's been working for about 40 of my clients who have called in about this."Leave a comment:
Are you talking about any kyocera devices ? and turning off 3DES ?
3DES encryption was deprecated along with TLS 1.0 and 1.1. Turn off 3DES under Effective Encryption. And make these changes under both Serverside and Clientside. That's been working for about 40 of my clients who have called in about this.Leave a comment:
Kyocera help desk helped with this one and it worked..Go to network security, turn off SSL, TLS 1.0 and 1.1 . Leave TLS 1.2 enabled, as well as SHA1 and SHA2 as they are needed for KFS.Leave a comment:
Some of our customer are getting intermittent 4803 errors. It was sort of hard to pin down what was going on because we test the settings with OK result. 20 minutes later 4803.
We were going to have some devices with TLS1.0, 1.1, 1.2 all selected on both server and client side and some with with only TLS 1.2 turned on.
Even with 1.2 just checked. (attached) I am still getting errors.
Is there any resolution to this issue?
My Version Info on our TASKalfa 4501i
System : 2N9_2000.004.505 Engine : 2N7_1000.004.002 Panel : 2N4_7000.004.501 Scanner : 2N4_1200.003.001 FAX : 3N6_5100.B06.001 Attached FilesLeave a comment:
