Measure to prevent IPP drivers from loading
  • kuby
    • Oct 2007
    • 1392
    This says it will keep IPP drivers from loading:
    1. Press “Windows + X” and select “System”;
    2. Under “Related Setting” or “Device Specifications”, select “Advanced System Settings”;
    3. Select the “Hardware” tab;
    4. Select “Device Installation Settings”;
    5. Select “No (your device may not work as expected);
    6. Click “Save Changes” and the “Ok”.
    7. Restart and change to proper drivers.
  • kuby
    • Oct 2007
    • 1392
    Some people report that some things do not work anymore and some were disabled? Have not had that problem on any of the computers I had done this to..
    • rthonpm
      • Aug 2007
      • 2847
      Alternatively, you can disable WSD and/or Mopria on the MFP or printer.
      • kuby
        • Oct 2007
        • 1392
        I disable both of those on all the machines I install.
