Papercut Hive Query
  • Kenny
    • Jun 2009
    • 529
    Papercut Hive Query
    Hi guys,
    probably a silly question but how do you actually get the paper cut hive software to first start installing the edge nodes etc on a clients pc,
    i know on papercut MF you go to your partner portal and can download from there but with hive there isnt a download link? do you get it when you actually put the order in for paper cut hive or not?
  • Copier Tech Specialist
    • Jan 2025
    • 19
    you need to contact your local Papercut Authorized Solution Center to get the demo link.
    • Hart
      • Feb 2024
      • 421
      You can download Nodes in your web instance
      • Blizzoo
        • Aug 2013
        • 608
        Originally posted by Kenny
        Hi guys,
        I recommend taking the online training for Hive if you have access to portal, is quite easy after you get the idea how it works even easier if you are familliar with MF
