Ricoh PCL6 V4 Driver for Universal Print what are your thoughts?
  • aviso66
    • Dec 2012
    • 202
    Hi what are your thoughts on this printer driver PCL6 V4 Driver for Universal Print for Ricoh?
    i tried it before one one printer and it prints out funny texts.
  • rthonpm
    • Aug 2007
    • 2859
    Re: Ricoh PCL6 V4 Driver for Universal Print what are your thoughts?
    Unless you have a real use case for v4 drivers, stick with the traditional type 3 driver.
    Type 4 drivers only support Windows, if you use them on a server they do not download to the client like a Type 3 driver would. If the client has the driver installed, it will use it; otherwise it uses a generic point and print driver, which can give you some odd output depending on the file type. Any shared print queue using a Type 4 driver cannot be used by another OS so any Macs, Linux, or mobile devices using the queue won't be able to access the printer.
    In theory, Type 4 drivers are a great idea: processor independent, able to be directly embedded into an application, and able to work outside of the the general print spooler. In reality, they're more trouble than worth.
    Sent from my BlackBerry using Tapatalk
    • green4go
      • Jan 2022
      • 51
      V4 drivers of any brand is slow and glitchy.
      • Dreama
        • Jan 2013
        • 43
        " from here - The New Microsoft V4 Printer Driver Model: What Admins Need to Know
        Brand irrelevant - if you can install the correct specific driver then that is the best thing to do.
