I am not sure anyone here can help but here goes... I have attempted to make use of the driver distribution package 1.3.5.0. This is the latest updated version as far as I know. The issue I am having is after configuring either the MSI verion or the silent install version the following occurs.
Driver installs,
The colour choice selection does not stay during a PDF session, it will automatically revert back to the choice that was inputed during the configuration of driver package, so if the driver was installed with the colour chosen in the confguration settings it will not change to B&W or vise versa, if you select to change the colour and click ok, the setting will revert back to the install default and the document will print using the install default setting. Most clients of ours like the default set to B&W with the ability to select colour during the print process.
This occurs on Windows 10 and 11, and using a number of PDF viewers (foxit or adobe etc..). Alternatively installing the kx driver using the kx installation package, the settings are easily toggled and the results are as expected.
Does not matter if the default configuration is B&W or Colour,
Driver installs,
