Trying to pimp this very old but very solid notebook, HP Elitebook 8730w with a LED backlight. The old CCFL became very dim, and I could find a new tube for it, but......, since I'm never satisfied with simple solutions, it must be a LED-stripe which I got already from China man.
The problem is that the driver board of China man's LED-stripe has four connections, GND, VCC, Enable and Adjust. That's clear, but the HP has six connectors without any labeling. I did found out (easy) what is GND and VCC, but the other four connections I'm unsure since the HP CCFL converter board has also an ambient light photo sensor incorporated.
Don't want to trash again a motherboard, which has happened before with another notebook with the same scenario
, so a pin out of the backlight connector of the HP Elitebook 8730w would be fine. Any help please?
Hans
Hans
